gsc cams nightmare
Old Sep 26, 2005 | 05:13 PM
  #61
Ozzmosis's Avatar
Try to work out a deal. Return the cams, Purchase a set of HKS 272's and call up buschur for a new set of valves and retainers and springs and try to get free labor. You don't really lose out this way and get some more parts.
Old Sep 26, 2005 | 06:31 PM
  #62
gsujeff55's Avatar
hmmm....
so, the shop that stands to be blamed for the bad install is going to measure the cam as well? wow, way to keep it honest.
Old Sep 26, 2005 | 06:57 PM
  #63
onpol's Avatar
gsujeff55- Sorry to spoil your conspiracy theory i do not have the cams in my possesion neither i'm going to meassure them cuz i don't have the means profesionally do so. The owner of the car is going to take them to someone else to do the measures. I see you have HKS cams on your car great choice
Old Sep 26, 2005 | 08:05 PM
  #64
DanJ's Avatar
Where are you located? If you are local I can take the cams to work and check them on the CMM to get an exact measurment of the cams. Just trying to help you out.
Old Sep 26, 2005 | 09:02 PM
  #65
bdking57's Avatar
I didnt want to believe it either when a cam gear install jacked up my car.. I was watching the whole procedure, but the timing belt went off two teeth and i ended up having to get all new timing belts.. luckily nothing was damaged, but yet.. at the end of hte day it was the installers fault.
Originally Posted by The_Predat0r
Guys, I was there and I took these pictures! This wasnt installer fault! it was a problem with the cams!
They have installed tons of HKS cams including my car, the installer really know what he is doing. They have only tried to install 3 sets of GSC but many many HKS. The first set of GSC they installed went without a glitch and the car runs great! The second car was the car of the installer, that second set also had a bad cam that woudnt fit, I remember we had to install a set of HKS that we had on site for other car and everything worked right, we called Greg from GSC and we shipped the cams to them and he refunded the money. Now months later and many cam installations later they try to install a third set of the GSCs and the cams also have problems, thanks God they never started the car with those cams! Evosorio had to drive for an hour for a new set of HKS, they installed the HKS and we didnt hear the problem anymore. We started the car and noticed the problem, it sounded like a compression problem, did a compression test and decided to take apart the motor, and then found out what you can see on the pictures!
Its definitely not an installer problem. The installer follows the recommended procedure and uses the tensioner tool etc. I trust this guys 100% and he has worked on all of my cars for many years, and he has been a race mechanic for many years with Mitsu engines, he was the mechanic of the world fastest door slammer for many years, 7 seconds Mitsu engine, also I was also there and saw everything.
Evosorio had to wait for one week for one of the cams and that was the one that caused the problem. Apparently a bad batch! but its the second time with only 3 sets! The first problem was that it didnt fit so it didnt caused any problem and we swapped the cams for a set of HKS, but this time we have some damage.
We are not trying to affect the reputation of GSC, but we simply wont recommend GSC cams to the locals anymore because of this bad experiences, we never had an issue with tons of HKS installed. The mechanic was telling me that he didnt liked the finish of the GSC cams and apparently on the new ones it was fixed, but still we are having other problems.
And dont simply blame it on the installer, we are trying to contact a local shop so they can measure the cam so we can get more info on whats wrong with the cam, one of the mechanics will post later and give specific details of what happened, I am not a mechanic and dont want to deal with the details. Thanks...
Old Sep 26, 2005 | 10:33 PM
  #66
Zeus's Avatar
Originally Posted by sr20det91
Heres the thing. You cant just look at the timing marks on the valve cover. You gotta pull the accessory pully and check the mark on the crank also. You also have to be sure you dont have it 180 degrees out of phase, because the marks will be lined up, but wont be in time.
Another thing, just because you put HKS 272s in afterwords dont mean a thing. For one the damage is already done and 2 you may have got it right the second time. Its pretty obviouse you guys messed up. I'd cough up the dough and make your friends car right again.
And don't forget to check the balancer shaft marks too... it also can be 180 degrees out...
Old Sep 27, 2005 | 05:23 AM
  #67
C6C6CH3vo's Avatar
You would think a cam manufacturer would have to go out of thier way and invest thousands of dollars to make a single cam with out of spec lift, duration, etc. If the cam was defective enough to have the valvetrain run off time, I'd think it would be visible. Best of luck getting everything resolved
Old Sep 27, 2005 | 11:21 AM
  #68
GregGSC's Avatar
Originally Posted by onpol
Me and my old friend did the cam installation on this car. First of all i will try to explain things as they happened i'll try to be brief and please spare my english we in Puerto Rico don't practice it very often and it is a little hard to explain this things in this language. We installed the cams and cam gears and before we started the car as we always do without the valve cover installed yet we spinned the engine by hand with a 1/2 racket and ext. to see if everything was smooth.We turn the engine and it made a weird sound so we put the valve cover on no bolts on it just to see if all the marks were aligned they were perfect so we took the valve cover out and slowly turned the engine and we noticed that the valves on piston 1 and 4 were staying open and when the engine return to tdc the pistons were pushing them back and that was the source of the hard ticking sound. I called the owner of the car for him to see it and we then source a set of 272 HKS. We installed the HKS and turn the engine and it was super smooth and we checked the marks on cover and engine they were fine so we started the car.The was messed up it didn't idle and when it got to normal temp it dies and it was hard to start it again so we checked compression piston 1 had 0 piston 2 had 147 piston 3 had 136 and piston 4 had 0. It was obvious it had valve damaged. We took the head out and took the pictures. Today we installed a head back and the car started with no problems.
I know i'm not perfect maybe i made a mistake but we have to measure the cams first to determine who to blame.
Here are couple of pictures of a set of GSC i tried to installed on my car and as you can see they were defective. The cams did not fit so i send them back to greg at gsc and he gave my $ back that was fine for me i'm not a whining internet racer like a lot of people on the forums so i kept my mouth shut and did not post here about it. So out of 250 sets they made is absolutely posible the machine cut one really bad. I have more pictures if you need them.
We have already told you earlier in the thread that you can send the cams back and we would be more than happy to check them out, but we have not received one email a phone call or even a PM regarding this issue. If there is an issue with our product we would like to hear about it or at least hear about first so that we can help or even fix a problem. We care about our customers not like some of the other manufactures that sell something and don’t care about the user’s of them, we want to make sure that our products are the best out there and that our customers are happy with our products, its not always about the money its about pride.
As far as the cams that you sent back to us with "fitment issues" they were test fit in our shop car and are still running in the car. BTW when you install cams you are suppose to use assembly lube which the cams that you sent back to us did not have any signs of use.
Greg
Old Sep 27, 2005 | 11:25 AM
  #69
QueefoEvo's Avatar
No offense but why would anyone sent a defective part back to that manufacturor to TEST for an issue? Wouldn't an independent party be a better choice????
Old Sep 27, 2005 | 12:16 PM
  #70
GregGSC's Avatar
Well the logical first phone call is always to the manufacture. I mean if you have a problem with your Sony TV do you call Pioneer? I call the manufacture because they have the most knowledge about their product.
Old Sep 27, 2005 | 12:25 PM
  #71
gOt BoOsT's Avatar
why didn't you install hks in the first place??
Old Sep 27, 2005 | 12:54 PM
  #72
QueefoEvo's Avatar
IDK, when it comes to engine damage like this, it's a different story. Having a problem with you TV is one thing, but if that TV catches fire and burns down your house, sony would blame your electrice and so on and on. There is engine damage, so you send teh cam back and teh manufacturor is like
"OH, it looks fine, we were not at fault"
Case closed right? Something and someone messed up, either the cams or the installer, SOMEONE is lieing, that is a FACT.
  #73
dsm95hybrid's Avatar
I have installed 30+ sets of cams, many of which were GSC. Not a problem with any so far. Installer error. GSC has great customer service. This thread has no factual data regarding proof of defect and I don't believe it.
Old Sep 27, 2005 | 04:27 PM
  #74
onpol's Avatar
Greg- I didn't call you this time because it was the customer who bought the cams not me i only did the installation. I'm not interested in doing you or your company any harm and as i told before i'm not a whining ***** and you did get my $ back after 5 phone calls and about a week after you received them but please be honest there is no way you could have fitted that 264 ex cam i sent you back months ago without cutting the excess of material it had to make it clear.The pictures talk by themselves. And about the lube thing are you just trying to make me look like a moron? There is no lube that can make a defective cam fit in place. We did not installed the cams thats why there where no lube in them as you can see in the picture the intake cam is the stocker we only test fit on that one.
As i told before when the cams get measure up we will know what happened and if i'm the one who committed a mistake i will admit it and post here.
got boost- The owner of the car like most of the people wanted to save a few bucks thats why he went with the GSC.
dsm95hybrid- I hope you never run into any problems with them because as you can see on this tread no one will believe you.
Attached Thumbnails gsc cams nightmare-gsc6.jpg   gsc cams nightmare-gsc4.jpg   gsc cams nightmare-gsc5.jpg   gsc cams nightmare-gsc7.jpg
Old Sep 27, 2005 | 05:35 PM
  #75
EVOtagger's Avatar
what exactly is wrong with the cam? It's difficult to tell from those pics
also, how did you remove your gears and timing belt that the gears are hanging so low and so loose?? When I removed my gears, i had them ziptied in about 3 places with a bungee cord holding them up to ensure that no teeth shifted...
just curious...not saying you are doing it wrong or anything
