IS my ENGINE OKAY??
Old Oct 4, 2005 | 07:40 AM
ibanez_926's Avatar
i dont get how that accidently happens
lol
Old Oct 4, 2005 | 07:48 AM
dsm95hybrid's Avatar
There IS NO REV LIMITER when you downshift into the wrong gear. I estimate about 10,000rpms. You will lose your rockers off the lifters in some instances. Should be OK, but if a rocker comes out, the valve cover needs to be removed and rocker replaced.
Old Oct 4, 2005 | 08:16 AM
Dan2510's Avatar
You should be good
Old Oct 4, 2005 | 08:29 AM
DaWorstPlaya's Avatar
Originally Posted by Stew
unfortunately rev limiters can ONLY work when the engine is speeding up due to fuel input (i.e. your heavy *** foot) and not when you shift into a lower gear. In that case, the speed of the car & transmission gearing will shoot RPM's up to a rediculous number, causing the valve springs to be overworked and 'Float' (i.e. not uncompress in time) then you're pistons have a field day with them. If you had a case of Valve Float you would most definitely know, it would sound like a monkey f*cking a football with a tire iron in your motor.. If all sounds/runs well, dont worry about it
LOL! I like you explanation the best ...
