just got an RMR intake.....
Old Oct 4, 2005 | 02:08 PM
MREVO8pinoy's Avatar
i just ordered an rmr intake and it looks like a easy setup, not too showey but simple... my question is... was it the right move for me on my MR....by the way.. i've got a greddy r/s recir. installed also.. so give me your feed backs cause i need to know if i'm on the right path with my MR. thankx peeps.
Old Oct 4, 2005 | 02:12 PM
Warrtalon's Avatar
Well, you did the 2 mods that we say NOT to do first, but it's not the end of the world, and they can/will be useful later. The first mods should be exhaust, mbc, and tune. Then, if necessary, you get an aftermarket BOV, depending on the boost you run. At least you recirculated your Greddy, though, so that's good. The intake is not needed at all, and you will need a tune to make it run right (also to get good power out of it).
GinuwineEvo8's Avatar
Intake should be the last thing on your list .. If you havent already - a Boost Gauge followed by a MBC ... Then work your way completing your TBE... and depending on your goals a fuel pump and a flash ...
There is no "right" path - but a intake shouldnt be your first mod .. the stock airbox is good for up to anywhere from 350-400whp before it becomes a bottleneck ...
Old Oct 4, 2005 | 02:13 PM
djskyy's Avatar
I would've saved it for a TBE, but oh well....since you have already ordered a intake, it should be fine....
Old Oct 4, 2005 | 07:28 PM
what type of exaust is recomm?
Old Oct 4, 2005 | 07:53 PM
SPANKED's Avatar
Best exhaust probably is the one made by...SEARCH!!! No it's not a company, I can't tell you what's the best but if you do a search you will find tons of posts, reviews, discussions and opinions...read up and make your own decision otherwise you may be dissappointed if you go with the first thing someone recommends.
Old Oct 4, 2005 | 08:19 PM
Warrtalon's Avatar
What type? The type that is stainless steel and 3" in diameter.
Old Oct 4, 2005 | 08:27 PM
dridge11's Avatar
I thought the best exhaust was the most expensive, full Ti with a diamond encrusted 5 inch tip?
Old Oct 4, 2005 | 08:35 PM
Warrtalon's Avatar
Shhh, keep that nugget of info secret!!
