JDM MR BOV or APS BOV?!?!
Old Oct 11, 2005 | 01:37 PM
sirloin1219's Avatar
hey guys help!?!?..i know about both..but im just wondering is the APS BOV overkill? will the JDM MR BOV suffice my needs? my goal is about 400-450 awhp. which BOV would you prefer?
Old Oct 11, 2005 | 01:39 PM
mike1023's Avatar
well i belive a BOV all depening on how much boost you are going to be runing. JDM MR BOV holds around 25psi
Warrtalon's Avatar
If you REALLY are going for 400-450whp (upgraded turbo), then just get the APS BOV. The APS is not overkill when you're going for huge power like that. When going for double the stock WHP, you should get top shelf parts.
Old Oct 11, 2005 | 01:40 PM
thx man..thats all i needed to know, cause im begining my journey and just want to make sure my path is crystal clear! =DD
Warrtalon's Avatar
Mike, that's embarassing. Please send all your posts to me first so that I can proofread them before you submit. I know English is your 2nd language, but at least make some effort. If you have to, type your sentences into MS Word and let the spell-checker fix it all for you...
Old Oct 11, 2005 | 01:42 PM
Warrtalon's Avatar
Are you sure you don't want to actually discuss this goal of "400-450whp." That's no joke, will take a lot of time and money, will probably result in a car that is not the most reliable, and will require more stringent maintenance. I just want to make sure you know what you're doing before venturing into something so extreme, especially considering the level of knowledge in some of your posts to this point.
Old Oct 11, 2005 | 01:44 PM
mike1023's Avatar
So sorry warrtalon I didn’t mean to take your first repost. And will do now on I will send to you for the proofread. And is that a big thing that English is my 2nd language wait a min. no its not. English is my first language thank you very much.
Old Oct 11, 2005 | 01:47 PM
2003evo8's Avatar
I like the mr blow off when my evo was in the 350 to 400 whp range i went threw about 2-3 diffrent one's before the mr blow off worked just right
Warrtalon's Avatar
Oops, sorry. I was giving you the benefit of the doubt using my Alabama public school education as a baseline for where any native English speaker should be in terms of grammar and spelling ability...
Old Oct 11, 2005 | 01:48 PM
yea i understand the maintenance and money and all that good stuff...but this is something that will carried over the next couple years or so. my evo will no longer be my daily driver once it reaches a certain point. all im doing now is gathering info so that i know what to expect in the future. i may not reach my goal, but ill do everything the right way the first time. thx for the advice though. also my knowledge may not be up to par as some of the other techie guys here..but that's what im here for..to learn! also taking an auto class for ****s and giggles to learn about the other technical crap. not bad for a guy that wears a suit and tie everyday =P
Old Oct 11, 2005 | 01:56 PM
Warrtalon's Avatar
Well, that's certainly the right attitude and a great approach. You DO want to make sure you buy parts ONCE instead of getting a lower-level part now that you later have to upgrade in order to accommodate your bigger mods, so getting the APS is a good idea, if in fact you are going to go nuts and upgrade the turbo later.
On the flipside, think long and hard about what your realistic goals are, because if you really aren't going to go nuts and upgrade the turbo, then maybe you DON'T need to get those extra-expensive parts NOW that won't ever be fully-utilized. What exactly are your goals? Are you just trying to make it a fast street warrior, or are you trying to make it a great car at the track? If a track car, what kind of racing...auto-x, drag, road, or rally? All of these questions will factor into what your ultimate goal should be. Once you have that goal set, then work BACKWARDS in time to determine what parts you need in which order, as well as the severity/quality/expense of each of those mods in preparation for the ultimate goal. If you end up being ok with just under 400whp for a car that is just driven and raced occasionally, then you could just stick with the stock turbo along with all of the supporting mods (meth/exhaust/boost/tune/piping). This would give you a ton of daily-driven power with isntantaneous spool. If you really want something that spools a little later but that gives nasty highway pull, then you could go ahead and do a larger turbo that would require more supporting mods and more complicated tuning. Decide those things now before purchasing expensive supporting mods.
The JDM MR DV is only $110 shipped and will hold 24-25psi beautifully, which would be good for over 350whp on the stock turbo with cams and meth. The TI exhaust you plan on getting also is not necessary...whether you want 250 or 550whp. It's just an incredibly expensive item that is a little lighter than SS exhausts...there is no additional power. Re-consider that plan as well...
Old Oct 11, 2005 | 02:04 PM
yea the ti exhaust is already been comprimised haha. im looking to a get a tb for less than 700 or so within the next month. my goals will be between autox and road. ill also be taking a couple driving courses in the meantime while im upgrading if your going to suggest those. but for those events what power levels would you recommend?
Old Oct 11, 2005 | 02:34 PM
Warrtalon's Avatar
You can get the Megan TBE for $550 from Zeus. I have it and it works great...just a little loud for me.
I wasn't going to suggest driving courses, but those are a good idea. I haven't done any, but have managed to do quite well at both auto-x and road racing (only once so far).
For auto-x, you definitely don't need much power...stock turbo is best and probably with no more than 350whp depending on the course. I've done great with just 280-290whp in all of mine, because I rarely get to rag out 2nd gear all the way. Some good low-end torque is good for coming around turns in 2nd gear at low rpm, though.
For road racing, you still need something that will spool up quickly. People with large turbos have to get stroker kits in order to spool the turbo up fast enough for the road course. On the 16G, your spool is pretty much instantaneous all over the course. My instructor a few weeks ago was so impressed, he asked if my Evo was twin turbo. He actually asked me 3 separate times, because he didn't believe me. What was happening was I was never lagging and was pinning him to the seat coming out of every turn. He was used to turbo'd cars, but was not used to instantaneous whiplash upon acceleration. At this time, I was probably around 320whp, since I was using 100oct.
Old Oct 11, 2005 | 05:16 PM
MitsuEvoIIX's Avatar
Does the JDM MR BOV bolt right on to the stock intake tube or is a hard pipe needed?
Old Oct 11, 2005 | 05:25 PM
ashton13's Avatar
I just got the APS a week ago. Install is simple( just do it with the car cold) and took me like 20 mins. Get yourself a stubby phillips screwdriver to install either one. The APS is nice tho, it holds boost better, and is only loud when you want it to be.
