True or False?
Old Oct 13, 2005 | 02:53 PM
EVOL EDO's Avatar
only cases i heard of were when the cars were stopped and at idle.
i also heard it could be caused by the knock sensor or vibrations disturbing the maf sensor
Old Oct 13, 2005 | 02:54 PM
SterlingEvo's Avatar
It's totally Tralse... I mean Frue.
Old Oct 13, 2005 | 02:56 PM
chronozon's Avatar
Originally Posted by dafarmer69
hahaha, no... go to a parking lot drive to 20 mi an hour and turn the key acc.. you will be fine... dont be stupid and turn it to lock though....
Never tried it and prolly will never either, but it's good to know.
Old Oct 13, 2005 | 02:57 PM
lookEVO's Avatar
it will not cause and accident, and mitsubishi doesnt care. stop created e-hysteria
Jared622's Avatar
When you are moving and the car is in gear the car will not stall anyway. You would have to be holding the clutch in or something of that sort. If the car is in gear even if you turn the car off as long as you have some speed the car will continue to run. It is the same principal as a so called "bump start". If your battery goes dead in a car with a manual trasmission then you can just push the car and put it in first gear pop the clutch and the car will start.
just my .02$
Old Oct 13, 2005 | 03:00 PM
boomtown's Avatar
exactly - if you stall while moving just pop the clutch - car instantly restarts
Old Oct 13, 2005 | 03:07 PM
res04's Avatar
Just install a flux capacitor...keep those pesky Camaros at bay...no more stalling, adds 69HP too.
Old Oct 13, 2005 | 03:10 PM
MeKilla's Avatar
true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true true
Old Oct 13, 2005 | 03:15 PM
JSYEVO's Avatar
yeah i dont think it will happen on the freeway in gear, cause that would mean that your revs are up, maybe if u were in neutral, but then you wouldnt be in gear. i think it only happens when you are stopped and idling. its never happened to me though
Old Oct 13, 2005 | 03:21 PM
PEOPLExpress's Avatar
I think i will have to concur
Old Oct 13, 2005 | 04:03 PM
Juiced's Avatar
I call BS....
Knock Sensor don't work on DB's they work on Hertz, the sensor only pulls timeing if it "hears" a certain Frequancy.
Old Oct 13, 2005 | 04:10 PM
Alias's Avatar
Rather it works on DBs or Hertz, it has been discovered to happen ever since the viii came out in 03. It has been documented here more than a few times. Try a search.
Old Oct 13, 2005 | 05:18 PM
Warrtalon's Avatar
I also don't think it happens on 05s. I've lined up vs many open-header V8s at the drag strip with no issue.
Old Oct 13, 2005 | 05:20 PM
gt5oh's Avatar
the drag strip leaves a lot of room between cars, where as the street might be a lot closer to each other
Old Oct 13, 2005 | 05:25 PM
Warrtalon's Avatar
Still not nearly as loud as the open header race cars I have lined up next to...ones that are revving up really high and launching on slicks.
