Car feels weaker
Old Oct 18, 2005 | 09:26 AM
jxyooj's Avatar
Car feels weaker
I've own my 04 evo rs for almost 3 month. After a month of owning it i started hearing a whinning noise. I took it to the dealer, it turns out to be a transfercase problem. They replace it and now it seems to be weaker. It might just be me but I think the bad transfer case might of gave me more power. But the car is quiet now.
Old Oct 18, 2005 | 09:27 AM
Curt@MrLed's Avatar
Former Vendor
check for vacuum leaks..
Old Oct 18, 2005 | 09:28 AM
GOKOU's Avatar
Yep check for vac leak. My car feels weaker on different days
One definite cure would be to drive a civic for 1 week.
Old Oct 18, 2005 | 09:30 AM
evo racing's Avatar
i had my TC replaced...and it started whining again but only slightly...and feels hella weak...i know what you mean
Old Oct 18, 2005 | 09:34 AM
4rcd6's Avatar
your TC whines all the time or what when having the issue your talking about?? Mine whines like a ***** in first but I thought that was normal. Just wondering what issues with whinning your reffering too.
Old Oct 18, 2005 | 09:40 AM
evo racing's Avatar
the first gear whine is normal....
at around 35 it start whining loud...then at 50 it goes away...at 65 it comes back with a grinding noise. Then above 80 its just hella whiney that you can still hear with while blasting music...but mitsubishi still doesnt know what it is...so iv been living with this curse for the past 2 months
Old Oct 18, 2005 | 09:41 AM
jxyooj's Avatar
My tc was whinning at high pitch noise in 4th and 5th gear, around 50 to 65 mph, after that it would quiet down. After replacing it, seems like turbo isn't working as good as before, i am wondring if Mitsubishi didn't install it correctly. I'll check the vacum hoses later when i get off work and see if i can find anything.
Old Oct 18, 2005 | 09:43 AM
4rcd6's Avatar
ok i was thinking yours must have been terrible or else they wouldnt have replaced it.
jxyooj's Avatar
Mistubishi diagnose it the first time i took it in, it took them like 2 weeks to order the tc because it was backordered. They said there was something in the tc that was broken and causing the noise, thye flushed it and didn't do much so they had to replace it.
Old Oct 18, 2005 | 09:46 AM
evo racing's Avatar
mine took two days to fix...and it was perfect after...then it came back but theyre telling me its not the TC this time...but its making the exact same noise...and iv never even launched this car
Old Oct 18, 2005 | 09:47 AM
evo racing's Avatar
oh and if you dont have a boost guage...i highly recommend getting one
Old Oct 18, 2005 | 09:57 AM
GOKOU's Avatar
Yes get a boost guage and looking at vac lines will not cut it. I suggest you do a boost leak test.
DaWorstPlaya's Avatar
Make sure they filled it back up with the correct fluid ... the Diaqueen LSD fluid ...
Old Oct 18, 2005 | 10:14 AM
jxyooj's Avatar
Is there a tutorial to do a boost leak test, i'm new to turbo cars. I believe they put the right fluids in i asked them when i got the car back and they said it was the diaqueen fluids.
Old Oct 18, 2005 | 11:14 AM
sleet's Avatar
Check for a boost leak.
