hurry!! how to remove radiator fan!!
im trying to install my mbc tonight and can't get that damn radiator fan out of the way?!?! how to do it!!! how!!!please help!!
well after numerous tries..i found out what's stopping it.. there is this metal peice on the right hand side that i just can't get the thiing around...ill try again tomorro =( oh well another day.
no it's not the bracket..i took that off before..but that black piece on the radiator fan is blocking me...i can most likely take it off if i take off the big coolant hose on the top but then coolant starts to get all over the place
yea tah'ts about where i am right now..but the sun just went down so i have to work on it tomorrow..but i basically get the gist of how it needs to go in. i need to bend the radiator hose though a tad more for it to fit just right. i hope it's not this hard putting it back in
well if u can't fully remove it. i believe you should be able to atleast raise it at an angle give you enough room coming from the airbox area to put in your arm to work on the hoses for the mbc.
