Where do you guys mount your turbo timers?
Old Oct 27, 2005 | 09:12 AM
  #31
nutrulz's Avatar
OK, am I just stupid or do '03s not have a sun glass compartment?
Old Oct 27, 2005 | 09:31 AM
  #32
Pd1's Avatar
Pd1
I have an 03 VIII with a sunglass compartment. Apparently not all are equipped with this feature, though. Perhaps the RS has a different options package..?
Old Oct 27, 2005 | 09:53 AM
  #33
ez's Avatar
ez
Any Evo (RS?) will have the compartment unless it has a sunroof. The sunroof mechanism takes up the space where the compartment would be. I have an 03 with no sunroof, and hence a nice place for my shades
Old Oct 27, 2005 | 10:04 AM
  #34
ez's Avatar
ez
Originally Posted by Aux.
Dude how in the Heck did you get your TT where the clock is ?? Is the clock still functional ? I wonder if there is anyway to remove the clock (useless P.O.S) and get that in there some how ? Probably some custome work . Anybody know a good custome shop in Arizona preerably near Tucson but anything will due !!
You remove the dash trim and unsnap the clock case from the fascia. I fabricated a bracket onto the back of the fascia to hold the timer so I would not have to modify (cut) the trim. I then velcro'ed the timer to the bracket. Due to the depth of he unit, I did have to modify the internal dash bracket for clearance.
  #35
hotrod2448's Avatar
I put my timer in the change cup to the left of the steering wheel. I originally had it in the cubby below the heater controls but, then I relocated my radio there and had to move the timer.
Old Oct 27, 2005 | 10:08 AM
  #36
nutrulz's Avatar
Thanks, I have a sunroof, so I'm not stupid. Shouldn't you have a sunglass compartment with a sunroof that just makes sense.
Old Oct 27, 2005 | 10:09 AM
  #37
Aux.'s Avatar
How much work was it to pull off your dash ? Also how did you go about making a brket for your TT ? Did you just bend up so sheet metal or did you have a shop make it ? I mean you would have to mount it to your dash some how ! Did you just use plastic rivets or did you biolt it in ? Give me a little more. I think this is where i want to put mine!
Old Oct 27, 2005 | 10:10 AM
  #38
Vroompsh's Avatar
i have mine mounted on the steering column, its very visible and is out of the way...btw, i don't have a sunglass compartment on my 03 GSR either, some of us definitly got jipped lol and i do have the sunroof package btw..
Old Oct 27, 2005 | 10:34 AM
  #39
gh0stch1ld's Avatar
I bought a cf plate for the cubby hole and cut out the dimensions of the hks type 0 timer. You can get those at myevostore.com
Old Oct 27, 2005 | 01:08 PM
  #40
cooldude7's Avatar
Originally Posted by HksSSq
Where is the Wire ?
The wires are routed behind the top of the window frame and down the side to the A-pillar... i had to extend the wires since the wiring kit was not long enough... my friend did this for me and he wanted the "stock" oem look
here is a close up picture from another angle
Old Oct 27, 2005 | 01:28 PM
  #41
Kee1pride's Avatar
do 05's not come with change trays or something?i never knew i had one. ill look when i get off work.
Old Oct 28, 2005 | 12:24 AM
  #42
CT9A-VIII's Avatar
Yeah, I dont think the 05's have the coin tray. Thanks for all your responses guys! I think Im gonna end up putting it under the cubby..still unsure.
Old Oct 28, 2005 | 12:52 AM
  #43
kmxxbadboy's Avatar
Old Oct 28, 2005 | 02:48 AM
  #44
edwin's Avatar
Originally Posted by Kee1pride
I put mine down here.
same here! BTW its nice!
Old Oct 28, 2005 | 08:16 AM
  #45
sleet's Avatar
Originally Posted by Pd1
(see attachment)
That's the same place I put mine, also how did you fit the boost guage into the cup? The back of my gauge had 2 screws comming out the back and it won't fit all the way into the cup? Shoot me a PM, perhaps another picture? I can't figure out how to fit in in there.
