Best intake that won't stall your Evo
Old Oct 27, 2005 | 06:13 PM
05-EVO-GSR's Avatar
Originally Posted by vboy425
stock box with K&N drop in
+1
Old Oct 27, 2005 | 07:13 PM
dubbleugly01's Avatar
Originally Posted by KazzEvo8
I had a brief conversation with Works on this when I was talking about other things and they say that (my interpretation and words, sorry if I've gotten anything wrong; call them to get the direct info) the MAF is counting on the honeycomb design the stock intake uses.
That being said, I did NOT ask them about how to get more air in once the stock intake is too limiting.
Personally, I have the BR mass air pipe which Works does NOT recommend because of the above issue. I installed cams at the same time and have not been tuned yet and the idle and lift after aggressive acceleration creates rough idle and occasional stall. This has gotten better after the ECU learns.
That's what I've heard, anyway ...
just an fyi, and you probably already know this, but the stock honeycomb is located in the MAF sensor itself, not in the intake pipe. So the switch to the BR unit will not change the stock honeycomb. The BR pipe may cause excessive turbulence that the honeycomb cannot account for, but your honeycomb is still in place.
Old Oct 27, 2005 | 08:09 PM
joeymia's Avatar
Originally Posted by evolvedmb
It has stalled on 4 occassions with the BR intake, before all this new hardware was installed. I don't want to start a flamewar between vendors, but it is being tuned by another tuner in Ohio currently. I just found another thread concerning this issue of "drivability" and stalling, and most people agree that the HKS or stock box is the best route to go, because they don't mess with the MAF.
Thanks for responding!
I am going with an Ecutech flash for now^^^^^^^^^^^^^^
Maybe an EMS down the road though
Your car was running bad so you proceeded to add more stuff? You don't need a new intake you need to figure out what is wrong and correct it first.
Old Oct 27, 2005 | 08:43 PM
vboy425's Avatar
first off my car did stall everytime i reset my ECU, after a mixture of highway and street driving the ECU pickup, no stalling.
Old Oct 28, 2005 | 12:57 AM
G20's Avatar
G20
Well! I had put 4 different kinds of intake on my EVO and no problem. K&N drop-in, K&N Typhoon, APS cold-air, and HKS RS. No problem at all. Run like champ. Off course I has them tuned.
Old Oct 28, 2005 | 01:05 AM
Soon2BEVO's Avatar
intake dont stall your car. something else is wrong.
Old Oct 28, 2005 | 07:00 AM
flabarm's Avatar
This is a first for me. The evo is the first car I've had that requires a tune just w/ an intake.
Old Oct 28, 2005 | 07:04 AM
justchil's Avatar
No probs with the BR intake (filter) here.. but I'm still using the stock intake pipe.
Old Oct 28, 2005 | 07:25 AM
Jrod@Buschur's Avatar
Do you have our old 2 bend style intake or the newest one that we released last year that is only 1 bend?
Jarrod
Buschur Racing Inc.
Old Oct 28, 2005 | 07:27 AM
EVO3675's Avatar
The stock air box creates a resonant frequency that the mass air reads, when you remove the box the frequency is no longer there to be read so the computer richens out for moment,,also if you are using an blow off valve to open atomesphere then this can most likely cause another stalling issue,cause once again the mass looks for a frequency of air to be injested that is no longer there and richens alot for a split second,,also the bov will hover open slightly while the throttle is closed pulling in unmetered air which the computer will try and correct for by lowering the idle
Old Oct 28, 2005 | 07:29 AM
kmcconn9's Avatar
yea its definatly not your intake that is causing the stalling issues. I have only heard of problems with the K&N Typhoon POS.
Have you had a tune yet, since the cams, or intake. Thats probably your problem. Could be them cams too...
Old Oct 28, 2005 | 07:30 AM
kmcconn9's Avatar
I had the AEM, with no problems and then I got it tuned. Since the initial tune I have added a bunch of BR goodies, and the BR Pipe kit and it works and fits ALOT better than the AEM...
Old Oct 28, 2005 | 10:53 AM
what!??????????? Who told you that?
Old Oct 28, 2005 | 10:56 AM
ibanez_926's Avatar
Old Oct 28, 2005 | 01:29 PM
David Buschur's Avatar
Thanks for chiming in Jarrod. I was going to ask the same thing. If you have the original 2 bend MAF pipe that is what is wrong. We quite making those about a year ago. The new MAF pipe we have idles perfectly, no tune needed, no idle problems, no stalling. It has fixed every car we put them on.
Maybe the other tuner can make one for you.
David Buschur
www.buschurracing.com
StreetThisEvo
Aug 4, 2009 12:04 PM
nitz
Jul 4, 2009 09:14 AM
David Buschur
40
Jun 2, 2008 12:37 PM
dubbleugly01
Oct 5, 2006 09:32 PM
evocbus
21
Jul 20, 2005 06:43 AM
