Best intake that won't stall your Evo
Old Oct 27, 2005 | 03:13 PM
evolvedmb's Avatar
Damn it!, I just noticed that I put "you" instead or "your" in the title I currently have BR stage 1&2, and just upgraded my turbo, cams, and alky injection. My car constantly stalls due to the BR intake, even before the new work was even performed. I have experienced total fuel-cut and electrical failure the 4 times that it has occured in the past 2 years. I am wondering if any other Buschur owners have this problem, or if any other companies intakes do the same thing to your car? What is the BEST product IYO, that improves Hp/Tq and "streetability"? Thanks for the responses!
***title fixed***
Old Oct 27, 2005 | 03:15 PM
bechbum82's Avatar
i have the injen intake...but thats all that i have fornow....no issues
Old Oct 27, 2005 | 03:22 PM
wallyevolution's Avatar
I don't think that it would stall w/ just the BR intake, maybe your cams. What are you tuning with??
conphuzed's Avatar
Maybe I'm mistaken, but I thought the stock intake was fine as is, at least it seems that's what people here are preaching.
Old Oct 27, 2005 | 03:33 PM
simevo's Avatar
Stock intake is fine for lightly modded cars. I have the Injen kit and it didn't lose any power with my mods but I can't say I gained a whole lot either.
But I believe most Evo's running 10's and lower in the 1/4 mile are using some sort of intake.
Old Oct 27, 2005 | 03:38 PM
Sam - PURE Tuning's Avatar
Former Vendor
Then again alot of those guys also run stand alones and eliminate the MAF and just use a good air filter onto a custom aluminum pipe to the turbo.
What kind of engine management are u using?
Old Oct 27, 2005 | 03:42 PM
evolvedmb's Avatar
It has stalled on 4 occassions with the BR intake, before all this new hardware was installed. I don't want to start a flamewar between vendors, but it is being tuned by another tuner in Ohio currently. I just found another thread concerning this issue of "drivability" and stalling, and most people agree that the HKS or stock box is the best route to go, because they don't mess with the MAF.
Thanks for responding!
I am going with an Ecutech flash for now^^^^^^^^^^^^^^
Maybe an EMS down the road though
Old Oct 27, 2005 | 03:48 PM
EVIL EVO 8's Avatar
ALL!!! Intakes mess with the MAF sensor only drop in filters are nondetectable to the MAFS
because they use the stock piping and does not flow any extra air from the tubing just the air form the K&N which is not much,EVEN THE HKS which i think is way over rated here.
Old Oct 27, 2005 | 04:01 PM
sleet's Avatar
HKS RS, worked perfect even un-tuned.
Old Oct 27, 2005 | 04:48 PM
denile's Avatar
I have the BR intake w/filter.No issues at all.
Old Oct 27, 2005 | 04:49 PM
vboy425's Avatar
stock box with K&N drop in
Old Oct 27, 2005 | 04:51 PM
MYEVOVIII's Avatar
From all the other Evo owners and myself I have to agree stock works great until you start to go with very aggressive Cams or turbo upgrade.
But if you get the car tuned it will run fine with most Intakes Except for the K&N typhoon (not drop in)which many Evo owners and tuners alike have had many problems
Old Oct 27, 2005 | 05:27 PM
dubbleugly01's Avatar
I would ask Buschur why your car is stalling. If they are no help, and blame it on your tuner, swap back to stock air box to see if the stalling stops. If it stops, there ya go! If not, you've got other issues.
Old Oct 27, 2005 | 05:31 PM
Spec'd's Avatar
HKS Super Hybrid Filter will drop right in.
Old Oct 27, 2005 | 05:32 PM
KazzEvo8's Avatar
I had a brief conversation with Works on this when I was talking about other things and they say that (my interpretation and words, sorry if I've gotten anything wrong; call them to get the direct info) the MAF is counting on the honeycomb design the stock intake uses.
That being said, I did NOT ask them about how to get more air in once the stock intake is too limiting.
Personally, I have the BR mass air pipe which Works does NOT recommend because of the above issue. I installed cams at the same time and have not been tuned yet and the idle and lift after aggressive acceleration creates rough idle and occasional stall. This has gotten better after the ECU learns.
That's what I've heard, anyway ...
