Evo 8 brings home SCCA Nat' Tour trophy!
Old Mar 19, 2003 | 12:20 AM
SS RX7 r2's Avatar
[QUOTE][i]Originally posted by Silencer
]Congrat's on a 4th place finish. Do you have any pics of the race with your EVO in it? Question?, Did the brakes fade at any point in the race? Some people in other forums were talking it needed some better aftermarket pads for the front. Thanks and give us updates on future races.
Thanks Silencer,
Someone called www.DVimaging.com wanted to sponser the car and will be posting pics soon.
As far as the brakes it's actually the opposite problem of fade, until they heat up there isn't much intial bite, I did get into the ABS after some of the fast sections. Hawk HP+ is what I will use if they make them yet, until then just standing on the pedal works fine.
Won't do the Pro Solo as the mutiple drag tree starts are much more abusive than I thought....I tried 5K launch and nothing but bog, not willing to do repetitive 6500 rpm starts on race rubber on a new car.
Old Mar 19, 2003 | 02:20 AM
WRC4ever's Avatar
how would you compare your evo vii to the us evo? pros? cons?
Well, I only drove it for a 25 second lap, on stock street tires.
From what I can compare with my evo 7 when I autoxed it stock with street tires, my evo pulls harder than the US version, especially down low. The turbo lag is apparent on the 8 versus my 7. Also, the 8 understeers quite heavily, whereas my 7 did not. My 7 has a very slight understeer, but I can fix that quite easily with another ACD ECU, and I am sure R tires will help as well. The US evo will need to have understeer dialed out with other means, since it does not have ACD.
The seats are also very wide compared to mine. They don't remotely keep you as tight as mine.
I will need to drive the 8 more to really compare it to the 7. But that's all I could see so far.
Karl
Old Mar 19, 2003 | 06:07 AM
erikgj's Avatar
Congrats Rick,
It was good to meet you there. For the brakes just remember that the calipers are the "F40" type Brembos. Measure the pad thickness and start looking. There should be a good selection of pads for it.
I'm trying to track down the "group N" knock back springs. Brembo make them for rally use but several UK types reccomend them as a good cheap upgrade. They help with the intial pad bite and brake feel. If I find them I will give you a shout.
Erik
Old Mar 19, 2003 | 06:19 AM
wtz's Avatar
wtz
Hi Erik,
Contact Phil at Coordsport in the UK. Thats where I got my knock-back springs.
Cheers,
Old Mar 19, 2003 | 06:38 AM
erikgj's Avatar
[QUOTE]Originally posted by SS RX7 r2
[B]
[i]Originally posted by wtz
You can get -2 degrees front camber and -1 degree rear camber without eccentric bolts.
WTZ,
Which position should the adjustment be for -2 deg in the frt? Do you know waht the stock camber and toe specs are? - don't have a manual yet.
Thanks
On 7s it come stock at -1 degree camber. For -2 degrees camber, turn the bolt 180 degrees. If I remember right the bolt hole is marked with dots.
Erik
Old Mar 19, 2003 | 06:45 AM
erikgj's Avatar
Hi Erik,
Cheers,
Cool I call Phil if I can't get them locally. Brembo USA is less than a mile from me. Did you need the gasket kit also?
Erik
Old Mar 19, 2003 | 07:43 AM
wtz's Avatar
wtz
Don't know if the springs go between the caliper piston and pad or behind the piston. If it's the latter, I may need a gasket set. Hell, I have'nt even gotten my car yet!
Cheers,
Old Mar 19, 2003 | 08:43 AM
erikgj's Avatar
Cheers,
Behind the piston. I have been told that the gasket set may be needed. So you should leave them packaged and ask if they can be returned before you buy. I guess they are expensive. Have not priced them yet.
Erik
Old Mar 19, 2003 | 08:46 AM
2Cool's Avatar
Where the heck did they get ths SS classification from?!? Word from the SCCA is classing in AS initially. Somebody seems to have issues against turbo imports at your location apparently...
Old Mar 19, 2003 | 11:08 AM
In2DeepSD2's Avatar
I'll be sure to post some of those pics tonight
Mario
Old Mar 19, 2003 | 02:24 PM
SS RX7 r2's Avatar
Karl,
Wow your times would've been up there in SM2, I felt bad they threw out Sat. times since you were leading ASP!
Rick
Old Mar 19, 2003 | 09:48 PM
SS RX7 r2's Avatar
FYI, here is a memo I sent SCCA concerning classification of the EVO.
Solo2 Classing Reccomendations for SCCA
Stock class
In SS the ZO6 weighs less than the EVO, has 75% more hp, 50/50 vs. 60/40 balance, more tire and a much lower CG. Of course, in the wet the 4WD equalizes all the above. In AS the E46 M3 is much more powerful and has a better balanced chassis.
The EVO compares favorably to the BMW E36 M3 in terms of performance, weight, tire size and hp. On a sweeper course the E36 M3’s balance and low end power would be superior, on a transitional course the EVO’s propensity toward understeer and would be more effective.
The car is very well damped from the factory and the stock tires are near R compound so the gains made through shocks and tires won’t be as dramatic as on other cars. In addition, unlike an oversteering car (ZO6, RX-7) a front bar doesn’t help.
Street Prepared
As the engine is only 2 liters and boost cannot be changed, very little hp gains can be made. Again, the car is very well damped from the factory and the stock tires are near R compound so the gains made through coil overs and tires won’t be as dramatic as on other cars. Weight is still 3300 lbs. and wheel wells are limited. Rear bar, camber, and shock tuning may be able to negate some of the understeer.
STX and SM
The EVO fits exactly to the rules of STX, 2L turbo, and while it would have hp advantage over the popular WRX in this class, the rules should allow approximately equal handling. If not excluded, the EVO would help to bulk up this class and the SCCA membership.
If the next Evo comes with active diffs, It should be excluded with the Sti, which should be illegal in STX due to the 2.5-liter turbo and adjustable center diff.
SM – the 2liter engine generates relatively high hp stock, but at 19psi turbo boost stock there isn’t much more room to go higher. Unlike turbocharging similar weight cars like a ’95 3 liter M3 or V6 S4 where 400 hp is possible.
Vehicle Dynamic Summary:
US EVO pros and cons
Pros: - Great performance in slippery conditions.
- Very good shock damping.
- Near R compound tires, Mitsubishi corp. says to expects 8,000 -10,000 miles.
- Brakes would show advantage only in heavy track use.
- Good seats.
- Excellent transitional repose and stability due to understeering 4WD system.
- Under $30,000 MSRP to be competitive with the WRX.
Cons: - High 3,300 lbs. curb wt.
- High CG, car is 57 in high.
- 60 /40 frt to rear weight balance.
- Understeering 4wd system.
- Lower than rated power rating with low turbo power at low rpm and turbo lag.
Old Mar 20, 2003 | 11:17 AM
WRC4ever's Avatar
Karl,
Rick
No kidding Rick. I had an amazing drive on saturday, only to see it cancelled out. I would've been sitting happy with a 1 sec lead over 2nd place !!!! Oh well.
I am not sure I can make it to Norton on april 6th, i might have work that weekend. But I will be at the ProSolo though.
Karl
Old Mar 21, 2003 | 09:32 AM
In2DeepSD2's Avatar
Here are some pics from the AutoX... btw, do you think you are the first official US release Evo to have participated in an SCCA event?
Mario
Old Mar 21, 2003 | 09:33 AM
In2DeepSD2's Avatar
