ported manifold
Old Nov 22, 2005 | 05:38 PM
EvoDan2004's Avatar
ported manifold
dose anyone have a ported stock manifold? if so did you have a tubular manifold befor or no. what was your experence on both. thanks. im desiding on stock, stock ported, or maxfold type manifold. thanks for the reply and help.
Old Nov 22, 2005 | 06:49 PM
EvoDan2004's Avatar
any body???
fsugatorbait's Avatar
+1.
Old Nov 22, 2005 | 06:52 PM
Spaceball 1's Avatar
in the process now. I have been machining it at work on a mill for about 10 hours so far. the 10.5 hotside and stock o2 housing are getting the same treatment. should be about the most flow possible from these parts. then there taking a trip to be coated.
Old Nov 22, 2005 | 06:57 PM
EvoDan2004's Avatar
please post your resolts here if you can. g/l. i just got a 10.5 hotside works 3 o2 housing and d/p. i need something for stock manifold and these are really the only opitions out there. id like to see what is the best way to go with proff or some kind on imput
Old Nov 22, 2005 | 07:05 PM
I found the guys that are makeing good HP and Torque numbers, even some companies, buschur, are running a ported stock mani. Im taking it to another level, complete gasketmatch of each part and huge porting on the most restrictive parts. It will be some time before im done though. I was gonna do the 3" works outlet i have thought of a way to get the stock one very close alittle over 2.75" i will have to see if it will hold gaskets though. and didnt want to rebuy a DP and the outlet.
Old Nov 22, 2005 | 07:06 PM
RNR has a new manifold that looks very nice and they claim very high gains like 40 hp and matching torque
Old Nov 22, 2005 | 07:11 PM
EvoDan2004's Avatar
it is also 900 bucks witch i cant see being worth it. im shore it is a great part but900.00 for it i think is way steep. and g/l with the o2 housing porting. i love works and there parts so i had to sport one.
Old Nov 22, 2005 | 07:14 PM
Not to mention that our small 16g dyno turns into a ski slope.
Old Nov 22, 2005 | 07:16 PM
EvoDan2004's Avatar
true. i meen i got the RNR c/t exsaust and i love it. im shore it is a good peace but i will never pay that kind a money for a manifold unless i had a turbo upgrade and a custom manifold made. i hope tho that after testing and people buying it that they see great things with it.
Old Nov 23, 2005 | 10:41 AM
EvoDan2004's Avatar
any one else have some info. thanks
Old Nov 23, 2005 | 11:47 AM
ct9a gsr's Avatar
David Buschur did a test awhile back on this topic... in one of his long threads.
I believe he construced his own tubular equal-length manifold (looked very nice) and tested it against his ported stock manifold.
I believe the difference in power was either minimal or the equal length manifold lost some power. Do a search and you may be able to find it. Buschur's porting jobs net great gains for such a low price.
Old Nov 23, 2005 | 11:53 AM
RnR Racing's Avatar
Yes, the manifold is not cheap, but it isn't cheap to make either. When you consider it takes 12 hours to hand fabricate and SS material cost, flanges, etc, etc. We aren't making much money off of these. On top of that it comes with a lifetime warranty and you have the ability to gain 40whp. It really is actually worth it when you look at it that way. To each his own, but we can't keep up with the demand as it since these things hit the streets.
Just imagine how much power it will make on a ATP 35R kit.
Old Nov 23, 2005 | 11:54 AM
SLVRNBLK's Avatar
Veteran: ArmyFCOTM Winner
I have a ported stock exhaust manifold, and O2 housing from Bushur racing. Im very happy with them , however don't know if any gains were achieved (need to hit the Dyno). I did notice that spool up is a alot quicker. I also have a 10.5 hotside as well.
Old Nov 27, 2005 | 11:07 AM
trinydex's Avatar
does br port match their ported manis? as in like... take off the material that is around the inlet and outlets so that everything is the same size?
