Check engine light help MBC
Old Nov 23, 2005 | 05:21 PM
BLK05evo's Avatar
I just installed a Boost controller and my check engine light came on!!!
I had a shop install a turbo XS and mt dad see's the hoses going to the wastegate and one to the turbo nipple. When i asked the guy who installed the boost controller he told me its a sensor he removed and if iwant the check engine light to go away he has to plug the sensor back in. I cant see the vechile for my self because im in Iraq at the time!!! So is the check engine light supose to come up when you add a MBC PLEASE HELP!!!! I dont know what sensor he is talking about!!!!!
Old Nov 23, 2005 | 05:32 PM
MrSpeedDemon's Avatar
What? You should really get someone on here to help you, removed a sensor, that doesnt sound right. I wouldnt drive it until I got clarification, especially if the engine light is on. I feel for ya man, ARMY here too, but why are you installing stuff when you arent even there.........? You should wait until you get back man. Anyway, cant give the setup for an MBC, but for stock setup the turbo & wastegate hoses T off and go to the celleniod, the hose from hte bottom of the intake goes to the cellenoid, and the hose from hte BOV goes to the connection near the top of the engine. Good luck.
Old Nov 23, 2005 | 06:04 PM
BLK05evo's Avatar
Ok i just talked to the guy who installed it and he told me that he took of the stock boost cellenoid and left the harness hanging that connects to the sensor on the boost cellenoid. He told me that i dont need that becasuse i have a MBC now. but the check engine will still stay on!!!!! he is going to give me back the stock cellenoid so i can connect it back to the harness that means that i still have to cap both prongs off right!!!! What to do?????????? Help!!!!!!!!!
bigfishs's Avatar
An MBC does not cause a CEL, nor does it need any soleniod removed. Look in the how to's section, find out how it is wired and send the shop the diagram, tell them u want it done that way (there are two separate ways if I remember correctly. Failing that, ge them to put it back to stock and get your money back. You can do it yourself when u get home.
Chrushev
Lancer Troubleshooting
13
Dec 7, 2016 09:08 PM
Nickbevox
Aug 22, 2014 06:05 AM
rocafellavc
Nov 27, 2012 10:35 AM
ModifiedMR
20
May 17, 2010 12:14 PM
turbo06evo
16
Jan 6, 2010 04:18 PM
