Truth Squad: 2003 TSB and Recall list
Old Nov 30, 2005 | 02:40 PM
Warrtalon's Avatar
21 TSBs and 1 Recall for the 2003 Evo. There was no list for 2004 Evos, and one of these says it counts on 2004s, but I'm not sure about the rest.
Truth Squad: 2005 TSBs and Recall
16 Mechanical TSBs:
2003 Mitsubishi LANCER
03 - Manual Transmission > POWER TRAIN : MANUAL TRANSMISSION [Part 102000 ]
TSB No: 0322001
NHTSA ID:
Date: November 01, 2003
Summary: newly configured 5th gear synchronizer sleeve for 2003 lancer evolution manual transmission. *ph IMAGE ATTACHED!
03 - Windshield Blower > VISIBILITY : DEFROSTER/DEFOGGER SYSTEM : WINDSHIELD : BLOWER [Part 138110 ]
TSB No: 0355008
NHTSA ID:
Date: October 01, 2003
Summary: debris (such as leaves, etc) entering the front cowl area may clog the evaporator housing drain tube. if this occurs, the evaporator housing may fill up with condensation and overflow into the passenger compartment, and into the blower motor
03 - Cooling fan > ENGINE AND ENGINE COOLING : COOLING SYSTEM : FAN [Part 062200 ]
TSB No: 0351001
NHTSA ID:
Date: January 01, 2003
Summary: special wiper pivot caps (grommets) onto the wiper pivot shafts to keep water from entering the blower motor, causing blower motor failure. *tt
03 - Body > STRUCTURE : BODY [Part 162000 ]
TSB No: 0342B001
NHTSA ID:
Date: July 01, 2003
Summary: water entry into vehicle interior. *tt
03 - Hydraulic Brake > SERVICE BRAKES, HYDRAULIC [Part 030000 ]
TSB No: 94
NHTSA ID:
Date: June 01, 2003
Summary: brake noise. 2003 lancer evolution. *tt
03 - Anti-theft ignition > ELECTRICAL SYSTEM : IGNITION : ANTI-THEFT CONTROLLER [Part 116300 ]
TSB No: 0354007
NHTSA ID:
Date: June 01, 2003
Summary: immobilizer system information update (2003 models). *tt
03 - Engine exhaust > ENGINE AND ENGINE COOLING : EXHAUST SYSTEM [Part 063000 ]
TSB No: 93
NHTSA ID:
Date: May 01, 2003
Summary: turbo vacuum meter kit. *tt
03 - Equipment > EQUIPMENT [Part 350000 ]
TSB No: 0351003
NHTSA ID:
Date: February 01, 2003
Summary: carbon fiber spoiler appearance characteristics. *tt
Make : MITSUBISHI
Model : LANCER EVOLUTION
Year : 2003
Manufacturer : MITSUBISHI MOTORS NORTH AMERICA, INC.
Service Bulletin Num : 116
Date of Bulletin: JUN 01, 2005
NHTSA Item Number: 10015626
Component: ENGINE AND ENGINE COOLING
Summary: ROUGH IDLE/MISFIRE. MITSUBISHI TECH TALK. *TT
Make : MITSUBISHI
Year : 2003
NHTSA Item Number: 10015631
Component: STRUCTURE:BODY
Summary: RECARO SEATBACK BOLSTER COVER (PART NUMBER CORRECTION). MITSUBISHI TECH TALK. *TT
Make : MITSUBISHI
Year : 2003
Service Bulletin Num : 115
Date of Bulletin: APR 01, 2005
NHTSA Item Number: 10015710
Component: ELECTRICAL SYSTEM
Summary: DIAGNOSTIC TROUBLE CODE (DTC) P0300 RESETTING AFTER REPROGRAMMING. MITSUBISHI TECH TALK. 2004 LANCER EVOLUTION INCLUDED.
Make : MITSUBISHI
Year : 2003
NHTSA Item Number: 10015719
Summary: RECARO SEATBACK BOLSTER COVER BREAKAGE. MITSUBISHI TECH TALK. *TT
Make : MITSUBISHI
Year : 2003
Service Bulletin Num : 113
Date of Bulletin: JAN 01, 2005
NHTSA Item Number: 10015217
Component: SERVICE BRAKES, HYDRAULIC
Summary: BRAKE BLEEDING PROCEDURES. *TT
Make : MITSUBISHI
Year : 2003
Service Bulletin Num : 05012004
Date of Bulletin: MAY 01, 2004
NHTSA Item Number: 10014353
Summary: DTC P0300 CODE. *EH
Make : MITSUBISHI
Year : 2003
NHTSA Item Number: 10014363
Summary: REAR DOOR JAMB PROTECTORS. *EH
Make : MITSUBISHI
Year : 2003
Service Bulletin Num : 0455003
Date of Bulletin: MAR 01, 2004
NHTSA Item Number: 10006466
Component: VISIBILITYEFROSTER/DEFOGGER SYSTEM:WINDSHIELD:CONTROLS/WIRING
Summary: HEATER TEMPERATURE DIAL HARD TO TURN. *TT
Attached Thumbnails Truth Squad: 2003 TSB and Recall list-synchro-tsb.jpg
Old Nov 30, 2005 | 02:48 PM
Warrtalon's Avatar
5 Service Manual TSBs
Make : MITSUBISHI
Year : 2003
Service Bulletin Num : 0511001
Date of Bulletin: MAY 01, 2005
NHTSA Item Number: 10015821
Component: ENGINE AND ENGINE COOLING:ENGINE
Summary: CYLINDER HEAD HEIGHT SPECIFICATION - SERVICE MANUAL REVISION.
Make : MITSUBISHI
Year : 2003
Service Bulletin Num : 0513006
NHTSA Item Number: 10016133
Component: ELECTRICAL SYSTEM:ALTERNATOR/GENERATOR/REGULATOR
Summary: ALTERNATOR FR TERMINAL VOLTAGE - SERVICE MANUAL REVISION. *TT
Make : MITSUBISHI
Year : 2003
Service Bulletin Num : 0554001
Date of Bulletin: FEB 01, 2005
NHTSA Item Number: 10015337
Component: ELECTRICAL SYSTEM:BATTERY
Summary: BATTERY LOAD TEST RATE CHART - SERVICE MANUAL REVISION. *TT
03 - Other > OTHER [Part 980000 ]
TSB No: 0300004
NHTSA ID:
Summary: evolution technical specifications. *tt
03 - Manual equipment > EQUIPMENT : OTHER : OWNERS/SERVICE/OTHER MANUAL [Part 355200 ]
TSB No: 93
NHTSA ID:
Date: May 01, 2003
Summary: rear spoiler (owner's manual error). *tt
Old Nov 30, 2005 | 02:50 PM
Warrtalon's Avatar
1 Recall
Only 1 Recall, and it's not a big deal. Just a sticker change...
Make : MITSUBISHI
Year : 2003
NHTSA CAMPAIGN ID Number : 04V138000
Mfg's Report Date : MAR 22, 2004
Component: EQUIPMENT:OTHER:LABELS
Potential Number Of Units Affected : 7278
Summary:
ON CERTAIN PASSENGER VEHICLES SOLD IN THE UNITED STATES AND PUERTO RICO, THE GROSS VEHICLE WEIGHT RATING (GVWR) AND GROSS AXLE WEIGHT RATING (GAWR) AS STATED ON THE CERTIFICATION LABEL ARE IN ERROR.
Consequence:
OVERLOADING CAN DAMAGE YOUR VEHICLE, ADVERSELY AFFECT VEHICLE PERFORMANCE, INCLUDING HANDLING AND BRAKING, CAUSE TIRE FAILURE, AND RESULT IN A CRASH.
Remedy:
DEALERS WILL REPLACE THE LABEL. THE RECALL BEGAN ON MAY 31, 2004. OWNERS SHOULD CONTACT MITSUBISHI AT 1-888-648-7820.
Mark Sebby's Avatar
Dont forget!
FYI = TSB Is a fix or a commom problem that is sent out to the dealership technicians in order to assist them with techincal issues that may occur in certain models! Basically it is inter-manufacturer emails from one service department to another or Mitsubishi collected data that is available for the serivce department.
If you are experiencing one of these problems, please bring your vehicle into your local dealership and let them know that you are aware of the TSB so they can properly fix the problem. This will (in most cases) be covered under factor warranty.
There must be an actual problem in order for them to fix it under warranty. I would not suggest complaining about a problem that does not exist (especially if you have mods that would void your warranty and are expecting Mitsubishi to honor the said warranty).
Hope this helps!
Best regards,
Old Nov 30, 2005 | 03:51 PM
kmcconn9's Avatar
thanks war, looks like im ok....so far
Old Nov 30, 2005 | 04:07 PM
nefblkevo's Avatar
See this pisses me off, cause my Recaro seat broke and the tech claimed that it was abused and didn't fix the part. I did get it documented at the dealership though, and I'm going to take it back and see if I can get it fixed.
Old Nov 30, 2005 | 04:25 PM
Warrtalon's Avatar
Take those TSB and NHTSA numbers with you.
Old Nov 30, 2005 | 04:34 PM
alby988's Avatar
can u find 2004 tsbs?
Old Nov 30, 2005 | 04:35 PM
Warrtalon's Avatar
There was no Evo selection for 2004, just the regular Lancer.
Old Nov 30, 2005 | 04:50 PM
kmcconn9's Avatar
I guess the bugs are all sorted out on the 04's...haha sure would be nice if it were the truth....
Old Nov 30, 2005 | 05:01 PM
CGs's Avatar
CGs
That's funny, my heater dial is kinda hard to turn - but I never thought to bring the car in on that one. That's good info, thanks Warrtalon.
Old Nov 30, 2005 | 05:13 PM
blueo4's Avatar
Thats funny and seems a little low!
I was in my buddys office checking 04's TSB's and holy **** batman, I love my car but I am drivng a FU<KING lemon!
door jams
paint
plastic door jam seals
ecu trip codes
trunk latch
wing
manual TA
UM
rear speakers
rear glass rattle
(by the way the new mitsu trucks leak and they have too take out the entire dash in some to put a seal trim in to fix it) i guess since the Evo rear glass dont leak they let it go .
Sorry I dont feel like typing so thats all for now!
Old Nov 30, 2005 | 05:55 PM
sleet's Avatar
How can you tell if the seats are broken? I heard my seat crack very loud one time awhile back, thought I broke somthing but I could never find it. Anyone got a picture of one to explain?
Old Nov 30, 2005 | 07:01 PM
honda-guy's Avatar
isn't there a TSB for tranny synchro on the 03?
my temp dial is sticking and hard to turn, i hope they don't void my claim because i have an exhaust.
Old Nov 30, 2005 | 07:05 PM
sleet's Avatar
^ Just put the stock exhaust back on and go in, 109MPH for your mods is good!
