Evo taking in Water!!!
Old Dec 11, 2005 | 04:20 PM
Jadiem's Avatar
if you still on the factory windshield,i would highly doubt thats what it is... if you have a sunroof, it could be coming from there.. usually the drain holes don't get clogged up until the car is relatively old, however it is possible... another thing you can check is the air conditioner... usually when it leaks on the passenger side, thats the culprit...
Old Dec 11, 2005 | 07:33 PM
EVIL MR's Avatar
take a look at the lower left corner near your left foot above that you will see wire cover running to the left fender , make sure it's not pushed . i had the same this on my 05 after i put the avs-r wires into it.
Old Dec 11, 2005 | 09:21 PM
andenbre's Avatar
Originally Posted by Jadiem
if you still on the factory windshield,i would highly doubt thats what it is... if you have a sunroof, it could be coming from there.. usually the drain holes don't get clauged up until the car is relatively old, however it is possible... another thing you can check is the air conditioner... usually when it leaks on the passenger side, thats the culprit...
you may have leaves in the heater case clogging the evap drain
Old Dec 15, 2005 | 05:46 AM
Ph3n1x's Avatar
Just to update....
Took the car to the dealer....
They were very professional about it. Said if it was a defect they'd cover it and if not it was on me. Well I knew it wasn't me but I guess the service advisor just had to say it.
Turned out a grommet on the kickpanel on the whell well was loose and a harness that was in place got loose. So they sealed it up and dried the carpets out.
Overall was satisfied...
will see if the problem is fixed.
BTW the dealer was a Blacklisted Dealer, Fountain Mitsubishi, in Orlando Florida
Old Dec 15, 2005 | 07:18 AM
chronozon's Avatar
When was the last time you checked under the rubber mat? If it's been a while since you checked, it could be because of the rubber mat you have in your car. The one draw back of having a rubber mat is that the moisture underneath the mat won't evaporate as fast as having the factory carpet mat, so the little-to-none moisture that does get underneath the mat will stay there over time. A friend of mine had that problem with his truck, he had some rubber mat put and and by the time he realized the moisture accumulated underneath has already rusted out the metal.
Old Dec 15, 2005 | 03:29 PM
Jadiem's Avatar
who is gonna take the guy seriously? look at his avatar...
Old Dec 15, 2005 | 03:40 PM
bdking57's Avatar
Originally Posted by Phenix_fyah
Most of them are for the 2003 year model....I can hear the dealers lame excuse already...
lol.. sorry to tell you, your sunroof leaked as a result of the after market intake you have installed.
marylandevo8
Dec 14, 2009 04:54 PM
Ceddy
Sep 28, 2009 06:01 AM
Grendelrt
Jan 18, 2009 06:13 PM
Chameleon
Mar 14, 2008 07:20 PM
EVIL MR
Jan 1, 2005 03:50 PM
