Mini Battery Issues
Old Dec 20, 2005 | 02:31 PM
hkfeet's Avatar
Mini Battery Issues
Hey guys its my first winter with a mini battery and gsc mounting kit. Its a odyssey mini battery and Im having trouble getting my car to start in the cold mornings. Does anyone know what are some other mini batterys with a bit more juice?
Old Dec 20, 2005 | 05:07 PM
yesevo's Avatar
get a honda civic stock battery ,,,its smaller than our evo battery/..
Old Dec 20, 2005 | 05:09 PM
Invoice EVO's Avatar
Veteran: Air Force
Buschurs mini battery hasn't given me any troubles yet. Slow to crank some time but kicks on.
Old Dec 20, 2005 | 05:10 PM
Richard EVO's Avatar
How much weight does a mini-battery save?
Old Dec 20, 2005 | 05:11 PM
taenaive's Avatar
20lbs
Old Dec 20, 2005 | 05:13 PM
fsugatorbait's Avatar
Ive got the same setup and have only noticed slower cranking when its really cold out, but the car fires right up.
Old Dec 20, 2005 | 05:41 PM
techause's Avatar
intersys genesis is working well as is the Braielle(sp?)
Old Dec 23, 2005 | 06:33 AM
8urv8's Avatar
I second that! I have a mini battery from Buschur Racing, works great so far.
Old Dec 23, 2005 | 06:52 AM
walkedu's Avatar
I live where it gets into the sub 0 temps EVERY night. My mini battery WILL NOT work when it's that cold. All i'm doing is using the stock battery that i mounted in the trunk for the winter, and as soon as spring comes, i'll switch to a honda motorcycle battery i picked up new for $45. Works like a champ!
Old Dec 23, 2005 | 07:13 AM
EvoJimbo's Avatar
My braille battery started fine in cold weather last year. HOwever, this year it doesnt seem to hold enough charge to start the car. Remeber mini batteries life span is only about 1.5 years. A freind of mine replaced his buschur mini battery after having it for close to 2 years.
Odessey batteries are not suitable for winters. They have very low cold crankin amps.
I plan to revert back to an optima battery and be worry free for years to come.
Old Dec 23, 2005 | 07:15 AM
tke_413's Avatar
No problems here in Texas! :P We did have an ice storm a couple weeks ago while I was at work. 1/2 the car was ice but it still started right up.
Old Dec 23, 2005 | 01:07 PM
hkfeet's Avatar
I have a power cable that was once connected to a amp can I use that to hook up to the positive terminal from the front to a extra mini to the rear for more juice? If I recall its not really a large cable though.
Old Dec 23, 2005 | 04:08 PM
Jasil's Avatar
Buscher mini battery here........and ZERO problems in 20 degree starts!!
Old Dec 23, 2005 | 04:14 PM
4TUN8's Avatar
IMO it's not worth the weight savings.
Old Dec 23, 2005 | 07:31 PM
HiRevnVIII's Avatar
Get an optima yellow top! probably the highest CCA, and its small. Optima's kick ***, you can mount them upside down, has the best vibration resistance of ANY battery, and will NEVER EVER leak since it does not use conventional acid, only drawback is its price, BUT you get what you pay for.
