Driving Habits?
Old Dec 21, 2005 | 09:04 AM
Rnm's Avatar
Rnm
Originally Posted by fullyloaded
I just leave it in the gear while I'm braking, and when I'm about to stop, I put it in neutral.
Example: Cruising at 35mph in 3rd gear and need to stop
Leave in 3rd gear and brake
When I'm about to fully stop, pop it in neutral
I do the exact same thing.
Old Dec 21, 2005 | 09:05 AM
Lazeum's Avatar
Originally Posted by walkedu
I usualy take mine out of gear and use straight brakes. I just don't want to down shift and get my RPM way up there you know? Unless i'm racing, then i'll do it.
If you're racing and you downshifting, you will destroy your gearbox even if they are synchro into it! You will damage as well your clutch.
When you're racing, the best practice is the double clutch. You car is made for this kind of moves. pedals are exactly at the right location
So when I'm driving slowly (speed limits ) I downshift + brake. When I'm going faster, I'm using double clutch + brakes. My brakes won't live forever but i prefer to change my brake pads than my gearbox!!!
Old Dec 21, 2005 | 09:21 AM
pgjoey's Avatar
Downshift and engine break the most. Always try to keep the rpm good when doing so. Also break while in gear some, in the lower gears.
Something new happening now that it is cold. When I downshift some times right as the clutch is engauging it sounds like a faint horn blowing. Seems to stay around even after the car is warmed up good. The clutch does not slip any I know.
Old Dec 21, 2005 | 10:44 AM
nnorris7413's Avatar
Whatever I feel like doing. Sometimes ill downshift + rev match, sometimes ill put it in neutral and coast, sometimes ill just push the clutch in and keep it in gear until im almost stopped. Depends on my level of laziness that day.
Old Dec 21, 2005 | 12:13 PM
Jakeg97's Avatar
Originally Posted by Phenix_fyah
Do you guys downshift and brake together to stop?
yes
Old Dec 21, 2005 | 12:42 PM
DaWorstPlaya's Avatar
Heel and toe all the time ...
Old Dec 21, 2005 | 03:11 PM
Kyoichi Sudou's Avatar
I feel amputated if I just coast down the road in Neutral... learn to rev match and heel toe in a beater car, the ability to do so will carry over to whatever car that you drive in after u feel it out.
Old Dec 21, 2005 | 03:15 PM
keevo54's Avatar
Originally Posted by ksattic
I've heard stories of cops with laser temperature guns stopping people and checking rotor temps. It never ceases to amaze me how many idiots will coast tens of miles down mountain roads on their brakes.
I really hope you are joking, or maybe someone told you this just kidding and you actually believed them
Old Dec 21, 2005 | 03:19 PM
LimPShoT's Avatar
Brakes?? never heard of em hehe. Just step on the Gas!!!
Old Dec 21, 2005 | 03:21 PM
P_A_STREET_EVO8's Avatar
I do both.
Old Dec 21, 2005 | 03:22 PM
NoTec's Avatar
I match rev when i downshift every car. I dont care if its my beater jetta or my bike. I have to do it across the board to remain consistant.
Old Dec 21, 2005 | 03:26 PM
kiddevo's Avatar
both together
Old Dec 21, 2005 | 03:37 PM
bigric09's Avatar
in the manual it says when you downshift to slow, anything over 25 use 3d gear, anything under 2nd, i usually follow this, i will slow down with brakes, downshift into 3d normally until i stop with the brakes and at some point in there i'd a thrown it in neutral
Old Dec 21, 2005 | 03:44 PM
stevo_mr's Avatar
Match rev downshift only way to go
Old Dec 21, 2005 | 03:46 PM
NoTec's Avatar
+1000^100 Its so much easier on the tranny when you know what your doing.
