Things Currently Broken on your Evo
Old Dec 22, 2005 | 07:36 PM
  #31
evolovinit's Avatar
Originally Posted by poormansracecar
The only thing broke in my Evo is the Driver's side wallet. I also have an intermittent broken passenger that whines about going too fast in turns and such (this makes a loud schreeking noise (sounds like screaming then followed by a SLAP!).
Yes jhero23, very common problem....
Old Dec 22, 2005 | 07:47 PM
  #32
4cefedgst's Avatar
Originally Posted by dubbleugly01
It shouldn't be a throw out bearing as that bearing doesn't doesn't see any load unless the clutch is depressed., but most likely just normal gear noise which is very common on the Evo's 5sp transmission. Again, no cause for concern.
That's exactly the point. The TOB is moving back and forth ever so slightly from the vibration of the engine. When the clutch is depressed there is now pressure on the TOB preventing it from rattling ever so slightly. What he's explaining is not tranny noise. The tranny should only whine on decel in gear.
  #33
ewoevo's Avatar
The only things broken on my EVO are the front bumper, left headlight assembly, left front quarter panel, and intercooler (slight accident).
Old Dec 22, 2005 | 07:54 PM
  #34
MondoBongo's Avatar
aside from the damage i did in my accident, the only thing i have broke is the nerves of several passengers.
Old Dec 22, 2005 | 08:00 PM
  #35
dubbleugly01's Avatar
your noise may be a throw out bearing, I don't know. What I do know, is the stock Mitsu tranny makes a lot of gear noise. This is common problem reported by others. Go to a lightweight flywheel and it gets worse. Just ask the vendors who sell lightweight flywheels if you don't want to take my word for it.
In your case, what's making the throw out bearing move at idle? Just engine vibration? but why does that make the throw out bearing rattle? The pressure plate is only rotating, and not moving axially, the bearing itself is under no load, the release fork is stationary, why is the throw out bearing moving? So if I took a throw out bearing in my hand, and shook it, it should rattle?
Old Dec 22, 2005 | 08:03 PM
  #36
Jhero23's Avatar
Originally Posted by Viciouslord
wow... i love you guyz
From Webster:
Love: attraction based on sexual desire : affection and tenderness felt by lovers
Let's not go that way....
Old Dec 22, 2005 | 08:05 PM
  #37
mac_05evo's Avatar
front lip, dang racoon...
paint chips everywhere..
  #38
Viciouslord's Avatar
lol...***, you know what i mean
Old Dec 22, 2005 | 08:11 PM
  #39
DCSilvrEvo's Avatar
78000 Engine running strong But Light bulbs light bulbs light bulbs!!!!! Rear Tails, side markers and instrument panel lights gone. Warning signals blown Do i need to continue?!
Transfer Case went. Brake line is FCKED up.
Old Dec 22, 2005 | 08:17 PM
  #40
evo4g63awd's Avatar
1. I have a bad ground for my A/F gauge under my car (bought it that way, havnt had time to fix) so any time it rains really bad, or it snows really bad I throw a check engine.
2. When its really really cold, my e-brake light reads that it's on.
3. When it gets cold (because of my SAFC) my car's rpms spike really really low at times causing the car to stall out, even if the clutch is in.
Old Dec 22, 2005 | 08:19 PM
  #41
Elite Evolution's Avatar
Tripple on the TOB, they just make noise, very similar to DSM noises.
Old Dec 22, 2005 | 08:22 PM
  #42
liquidchrome's Avatar
oh yea i forgot...
chip on windshield... came out of nowhere. looks like a perfect 5 pointed star though
OOoooo pretty!!
Old Dec 22, 2005 | 08:28 PM
  #43
Jhero23's Avatar
My Speedometer, not sure what's wrong with it for some reason it keep going over 80mph.
Old Dec 22, 2005 | 08:30 PM
  #44
akEvo's Avatar
....my clutch, but not for long
Old Dec 22, 2005 | 08:38 PM
  #45
SnakeEater's Avatar
No probs here, I guess Im lucky
