help please!!!!!!!!!!!!!!
Old Dec 23, 2005 | 07:41 PM
carbonevo8's Avatar
Well guys I ran into a big problem and need some help. Heres my synario I have a 03 evo and I installed and WR turbo w/ high pressure actuator, FIC 750 injectors, Works 65mm throttle body, Helix IC pipe kit, Works 3inch 02 housing, Agency Power fuel rail, and Works BOV. I put the stock air intake back in with the works air filter. I had everything tuned by works I have a custom P2R flash. So heres my problem when the car is in gear or in neuteral it will only go up to 4800RPM and then it hits either a rev limiter or a fuel cut I can't tell I personaly thought they were the same. I checked everything to make sure everything is hooked up and it looks good to me. Is there something that I could have missed? Could the flash be bad? I haven't adjusted the throtlebody at all yet either so it idles at around 1500RPM. Any help would be great thanks guys and have a merry christmas.
I posted this in 2 places because not everyone reads the works forums
Old Dec 23, 2005 | 07:46 PM
1Crazy8's Avatar
what do u mean it will only go up to 4800?
Are you revving it in N?
are u flooring it in any gear and it hits a limiter/cutout at that point?
Please be more specific!
Old Dec 23, 2005 | 07:48 PM
Warrtalon's Avatar
You put the stock airbox back on right? Did you also re-install the stock intake snorkel? If so, did you actually put the clips in to fasten it down to the front bumper? I hope this is it, but I don't think so, since it is happening at 4800rpm and even in neutral.
You say you were custom tuned by Works. Didn't they go above 4800rpm when tuning it? Did it change and start doing this after the custom tune?
Btw, hitting the rev limiter just makes a fast popping noise, and your rpms flutter at the rev limiter while fuel is cutoff, but not like fuel cut. When you hit fuel cut, it's like hitting a brick wall and all your power goes away instantaneously. It's a very disturbing feeling. This feeling can also occur when an IC pipe blows off under boost.
Old Dec 23, 2005 | 07:55 PM
carbonevo8's Avatar
ok well then its a rev limeter for sure then. It doesn't matter what gear its in it will only go up to 4800rpm then it hits the limiter. The works p2r is a Brain Flash P2R represents an upgrade to the Brain Flash P2 by modifying the two-stage rev limiter. It never did this before the flash. I put the stock intake in correctly just as you asked above. Is there anything else? Has anyone ever gotten a bad flash? Heres is a link to the flash I have too
http://www.worksevo.com/store/produc...roducts_id=121
thanks
Old Dec 23, 2005 | 07:58 PM
Warrtalon's Avatar
Maybe the rev limiter has been mistakenly set at 4800rpm? I thought you said it was custom tuned. That would mean it was done in person on a dyno or on the street. Did you just receive a mail-in type flash?
1Crazy8's Avatar
something with the 2 stage rev limiter, not sure tho!
Good Luck!
Old Dec 23, 2005 | 08:10 PM
carbonevo8's Avatar
well its a mail in flash that is tuned for my mods that are on my car so thats what they call a custom tune at works. no it wasn't done in person. I wish it was then I don't think I would have this problem. I think its the 2 stage rev limiter too. I will have to call them next week hopefuly they will know. I can't think of anything elese that it could be. thanks guys
Old Dec 23, 2005 | 09:24 PM
Evo442's Avatar
I'm no expert by any means, but it sounds like there's a problem with the flash. Call Works, I'm sure they'll make things right.
Did you upgrade your fuel pump? My understanding is that Works strongly reccomends an upgraded fuel pump with the WR. Probably even more so with the 750cc injectors.
Old Dec 23, 2005 | 09:49 PM
bacalhau16's Avatar
Since u did change the throttle body, u had to have unplugged the tps, which im assuming evo's still have like all other cars. If this was still unplugged or u pull a wire out of this harness, im sure this could happen.
(TPS stands for Throttle Position Sensor, for those who arnt sure)
Old Dec 24, 2005 | 09:58 AM
evolved04's Avatar
this is a crappy deal and i cant help much, but i was there and before 4800 RPMS this car pulls like hell. if you need anything mike lemme know.
Old Dec 24, 2005 | 10:48 AM
carbonevo8's Avatar
thanks for all the help though josh this thing is killing me. the tps is pluged in and I checked all the wires and they are pluged in as well. I do have a walbro fuel pump installed. Here is a total list of all my mods
Works drop in filter
White rabbit turbo
Forced Performance HP Wastegate actuator
Helix IC pipe kit
Works 65mm throtle body
FIC 750cc injectors
Walbro fuel pump
Magnacore 8.5mm plug wires
Works 269 cams
Works 3 inch o2 housing
Helix 3 inch DP
Helix 3 inch cat delete
Helix 3 inch cat back
All of this is tuned by a Works p2R flash
thanks for all the sugestions guys and I'm trying them all and reporting back if there is anymore sugestions please let me know. I hate to think its the flash but thats all I can think of.
Old Dec 24, 2005 | 11:18 AM
Jakeg97's Avatar
Originally Posted by carbonevo8
So heres my problem when the car is in gear or in neuteral it will only go up to 4800RPM and then it hits either a rev limiter or a fuel cut I can't tell I personaly thought they were the same. \
does this happen when the car is moving or at a stop?
Old Dec 24, 2005 | 11:21 AM
carbonevo8's Avatar
it does it both ways. dead stop or moving in gear or in nuetral either way it does it. It also idles at 1500 I thought it was just warming up but it never went down sorry but I just noticed this
Old Dec 24, 2005 | 11:41 AM
Jakeg97's Avatar
sounds to me your pr2 flash is not correct for the mods you have
did you list of all your mods (not leaving any out) to works before the flash?
speaking of mods, for your amount, shouldnt you be getting an in-house tune instead of mail-in flash?
Old Dec 24, 2005 | 11:49 AM
carbonevo8's Avatar
well I had the works p2 and most of the mods already I just added some more things and since I already had the flash the update was free and they said they have a flash for all of my mods so I went with them again. I know of a few people with the same mods running with there tune. I live in the sticks and there isn't anyone remotely close to even tune a evo. I didn't leave out any of my mods when I talked to them and also I mailed them a list as well. I also think it is the flash. the 2 stage rev limiter is set wrong I think. Also the idle is wrong as well.
