Exhaust Expanding under heat??
Old Jan 3, 2006, 12:30 PM
Sxhawnn's Avatar
Hey I don't know if this is a newb question but I did search. I'm in the process of purchasing an RMR exhaust and the seller told me that the exhaust expands under heat. He said that one time it even caused his car to shut down on the freeway because of a bad install and the o2 sensor was triggered or something. Is it normal for exhausts to expand under heat. If so what can be done to avoid any complications?
Old Jan 3, 2006, 12:36 PM
bigfishs's Avatar
Almost anything expands as it gets hotter. Metals especially so. An exhaust will expand most along its axis (the same way railway lines expand mostly along their long axis).
This should not be a problem as exahusts are on hangars, and the amount of expansion should be relatively small. The O2 sensor on mid pipe wont cause your car to shut down, it will just give you a cel if something happens. And the one on the turbo housing shouldnt be affected as a TBE exhaust starts after it.
Old Jan 3, 2006, 12:37 PM
sleet's Avatar
I have never heard of exhaust expanding, nor shutting off on the freeway because of a bad install?
That makes no sense at all.
Old Jan 3, 2006, 12:40 PM
res04's Avatar
Exhausts do expand in length. Go to 3 1/4 mile runs then go look at it.
