Heater Issue...HELP!
Old Jan 9, 2006 | 06:08 PM
EVOLVEU's Avatar
nope, only sometimes. fan works fine. I will try that b4 I take it to pepboys tomorrow. My friend suggested it might be the same thing!
Old Jan 10, 2006 | 06:19 AM
EVOLVEU's Avatar
Turns out theres a leak in the radiator itself. Now the issue at hand is: fix it(stop leak) or replace it?
Old Jan 10, 2006 | 07:28 AM
Stew's Avatar
Any broken part is a great excuse to upgrade
..but if you are looking for the cheaper route, you may be able to find a radiator shop around that can braze the break, depending on the size of it. I had that done and it worked perfectly. Never had any luck with any of the "Stop Leak" type things though. Price from the radiator shop was like $20..
Old Jan 12, 2006 | 01:11 PM
MIevo8MR's Avatar
I don't recommend you using stop leak. I work with HVAC systems and most stop leak brands just puts all types of residue through your cooling system.
I'd go with the brazing like Stew mentioned, or even replacing and upgrading with a new radiator.
Old Jan 15, 2006 | 01:56 PM
EVOLVEU's Avatar
I got a koyo(it was a huge hole in the radiator, under the fan), but now its really bad... heres the new thread...
https://www.evolutionm.net/forums/sh...d.php?t=179067
Old Jan 15, 2006 | 02:30 PM
use2vtec's Avatar
In my old Honda I had the block sleeved and the company that sleeved it (goldeneagle) recommended that I add stop leak to ensure no leaks will occur. I used this stuff and about 6 months later we had to pull the motor apart and just like mentioned above there was residue through out the enire system. Stay away from Stop-Leak!!
Old Jan 15, 2006 | 02:44 PM
EVOLVEU's Avatar
Ive heard bad things about it too, I just threw the koyo in it. BTW, its an awesome radiator!!!
RyanD3
Lancer Troubleshooting
Nov 12, 2016 01:14 PM
3bar_dc2
13
Jul 1, 2016 02:04 PM
blacktab420
Jan 3, 2014 10:28 PM
car_nut15
17
Jul 7, 2011 09:18 PM
