Rev limiter not until 7800-7900rpm. :)
Old Mar 26, 2003 | 07:52 AM
Scot's Avatar
Not sure how much power it is making above 7000rpm, but my car does not shut off until about 7900....which makes the 0-60 a 1 gear switch instead of 2 (just in case somone wants to race you to 60mph).
Old Mar 26, 2003 | 08:18 AM
leonard_shelby's Avatar
I'm fairly certain top end (just before redline) of 2nd gear in the EVO VIII is prolly 72 - 75 mph..
Can any owners comfirm ?
So why would you have anything other then 1 gear change anyway (without darting past the redline) ?
Old Mar 26, 2003 | 08:30 AM
Scot's Avatar
I did not pay attention, but i thought I read in SCC that they needed to switch to 3rd gear (switching at the redline) to get to 60 mph.
Old Mar 26, 2003 | 08:33 AM
holy **** .. that sounds like a 6 speed to me... maybe the EVO is geared a whole lot lower then I thought
Old Mar 26, 2003 | 09:02 AM
Just checked, Road and Track claims 7K RPMS in 2nd gear = 60MPH on the dot
Old Mar 26, 2003 | 09:58 AM
trs94's Avatar
Here are the top speed in gears based on gearing calculations with the stock tires:
7000 RPM Shifts
Gear Speed
1 39.73
2 59.70
3 82.57
4 113.03
5 161.70
7500 RPM Shifts
Gear Speed
1 42.57
2 63.97
3 88.46
4 121.10
5 173.25
7800 RPM Shifts
Gear Speed
1 44.27
2 66.52
3 92.00
4 125.95
5 180.18
TRS
Old Mar 26, 2003 | 10:33 AM
darknightohio's Avatar
180 mph wow.
Old Mar 26, 2003 | 10:35 AM
at way over redline
Jonasan50's Avatar
180 MPH, KAPOW!!!!
Old Mar 26, 2003 | 01:35 PM
jotan82's Avatar
wow
Old Mar 26, 2003 | 01:47 PM
evoloverebdb's Avatar
Hey claudius, is it ok with the 4g63 engine to rev it that high? is there a point that we sould stop without causing a see-through engine? (i'm speaking a stock to lightly modded engine, not the stroker you have, though I'd like to know what your limit is!)
dave
Old Mar 26, 2003 | 02:12 PM
Guack007's Avatar
Probly with such a huge stroke the engine's limit will be lower. Read that stroker engines put alot of stress on the rods and crank bearings. Are the valve springs and retainers titanium in a stock evo8 ???
