Hollowed out HFC= test pipe
Im thinking about getting a test pipe since I dont need emissions where I live. Right now i have the helix high flow cat, would hollowing out the hfc be pretty much the same as getting a test pipe?
Measure the total length (20.5" if I remember correctly) and have any local performance / muffler shop weld up an extension pipe. Tell them you are extending a regular cab truck to make it extended cab and need the extra length. That way they don't have any trouble "replacing a cat".
Well getting a test pipe isnt a problem, the shop that I had my v8 s10 exhaust done at will make a test pipe, but im wondering what the difference is between the hollowed out hfc and the testpipe.
I would think the exhaust flow would be faster and less turbulent with a test pipe than with a gutted cat. I've got a slightly used Perrin cat-delete here you can have for $20 if you want. I switched to a DC Sports downpipe that has the cat-delete built-in, so I don't need the Perrin anymore.
Now days you can get a test pipe in the $60 range. It would be a pittyfull waste of money if you use the HF cat as a hollow cat. At least keep it, it could be beneficial in the future.
kikiboi
Sep 5, 2007 05:09 PM
