As requested, here's a vid of my 2-step Dynoflash launch control
Old Jan 16, 2006 | 12:49 PM
SterlingEvo's Avatar
Originally Posted by hukster00
I cant play it do i need some codecc ?
it's just a regular WMV file... I made it in the simplest program ever: Windows Movie Maker. There should be no reason you can't see it. Unless you have WindowsMediaPlayer v 1.0
Old Jan 16, 2006 | 01:37 PM
hukster00's Avatar
downloaded the classic player seems to work fine , Whats the diffrence between this and what comes with the 05/06 evo ?
Old Jan 16, 2006 | 01:44 PM
m32001's Avatar
Heh, Very cool!
Old Jan 16, 2006 | 02:38 PM
This is set at wherever you want, in this case, 6000rpms. Its 2 step design allows you to build boost at the line. The Mitsu is nothing more than a rev limiter that keeps you from going beyond a certain point in neutral.
Old Jan 16, 2006 | 03:44 PM
hukster00's Avatar
i think i so a post somewhere that a member was building boost with it also O_o
Old Jan 16, 2006 | 03:46 PM
4TUN8's Avatar
Video is awsome, I can't wait for my two step =/
Old Jan 16, 2006 | 03:49 PM
eve-slow's Avatar
Is the 2 step boost building feature going to have negative long-term effects on the turbo?
Old Jan 16, 2006 | 03:52 PM
m32001's Avatar
I heard that the two-step does shorten the turbo's life.
Old Jan 16, 2006 | 03:59 PM
nefblkevo's Avatar
why did the car side step right just after the shift to first gear. was that the blizzeek effect.
Old Jan 16, 2006 | 04:01 PM
kErViOsVIII's Avatar
sick!....
Old Jan 16, 2006 | 04:25 PM
Warrtalon's Avatar
Actually, yes, you do build boost on the stock limiter at 5k, but it's not quite as much. Some people launch off the stock 5k limiter just fine, but I prefer it to be at 6k. The great thing is that it is now adjustable according to the Dynoflashed customer's wishes. You may prefer 5200, 5500, 6000, 7000 - all are fine. It is definitely possible that the 2-step shortens the turbo's life, but Mitsu puts one on every Evo now, so I'm not too worried about it. I also try not to do it unless I'm at the track (or for a video).
Old Jan 16, 2006 | 04:26 PM
Warrtalon's Avatar
When I snapped the 1-2 shift, the rear end kicked. That doesn't usually happen, but the Blizzaks aren't great for traction, and the ground was really dirty and dusty.
Old Jan 16, 2006 | 04:36 PM
steevo's Avatar
Awesome!!! I'm jealous...
Old Jan 16, 2006 | 05:10 PM
DreamLike1's Avatar
cant view the video rehost plz!!
Old Jan 16, 2006 | 05:18 PM
mike1023's Avatar
hehe i lunch off stock 2 step and i spin tires with stock tires too. and i build around 7psi or so. which is nice lol. not to much to make back end go all over or to much to get out of control
