Question about AWD DynoJets and WinPep7...
![Question](https://www.evolutionm.net/forums/images/icons/icon5.gif)
This question is out of pure curiosity and has to deal with AWD DynoJets and the WinPep7 program used to operate the dynometer and process the data created by them...
Here's what I understand so far and please correct me if I'm wrong...
On 2wd dyno graphs, on the left side it'll say "Power (hp)" and on the right side it'll say "Torque (ft-lbs)". This will show the power for one roller, which is appropriate for a 2wd car.
On 4wd dyno graphs, on the left side it'll say "Total Power (hp)" and on the right side it'll say "Total Torque (ft-lbs)". This will show the power for both rollers, which is appropriate for a 4wd car. If the two parameters are left to read "Power (hp)" and "Torque (ft-lbs)" on an AWD graph, it'll only show the power produced by one roller... you have to specific that you want the Total power of both rollers for AWD graphs.
Now, assuming all that is 100% correct... is it possible to manipulate WinPep7 to display the total power of an AWD vehicle on a graph without using the "Total Power (hp)" and "Total Torque (ft-lbs)" options and instead have it display "Power (hp)" and "Torque (ft-lbs)" on both sides?
Any input from AWD DynoJet operators would be great... thanks ahead of time.
One thing to note is that the new software on the Dynojets themselves only say "Power" and "Torque" as I found out this week. We kept looking for the "Total Power" and "Total Torque," but those parameters were nowhere to be found. A call into Dynojet said it was a change with the new software.
However, when putting those same files into my current version of WinPep, I still have those options and they DO show different numbers, respectively.
BLMW
Lancer Ralliart Vendor Classifieds
May 31, 2012 08:03 AM
PERRIN_JOHN
24
Apr 23, 2009 11:01 AM
whiterexman
19
Dec 17, 2003 05:14 PM
