IX MR Hating!!
Old Jan 25, 2006 | 09:38 AM
  #31
BluByWho's Avatar
You must have run out of headlight fluid........glad to hear its ok!
Old Jan 25, 2006 | 10:13 AM
  #32
GTSMWET's Avatar
i blew off my Buschur UICP, and yeah its freaky when it happens, luckily i was just taking it out for a test drive and i was right by my house. It was loud, and it smelled like someone lit a bottle rocket. its freaky, but hey now you know
Old Jan 25, 2006 | 10:34 AM
  #33
nigletsyz's Avatar
pipe to your throttle body blew off.
Old Apr 27, 2006 | 02:40 PM
  #34
zgodfathera's Avatar
LOL it just blew off again on lunch.... pop out my phillips and back on the road.....
Old Apr 27, 2006 | 02:46 PM
  #35
nubby's Avatar
Registered User
Read up on this board about T-bolt clamps. They're far superior to the worm-gear clamps that come from the factory that hold all the intake plumbing together.
Might be worth a try since it seems you have a bum clamp.
Old Apr 27, 2006 | 02:50 PM
  #36
gsrboi80's Avatar
Yea for sure, Get all new clamps.
Old Apr 27, 2006 | 02:53 PM
  #37
brooks1005's Avatar
Now you know your problem area.Head to NAPA and buy a box of 2.5 inch T-Bolt clamps.
Old Apr 27, 2006 | 02:56 PM
  #38
True i think i might have to that... how many clamps total do u have to buy?
Old Apr 27, 2006 | 03:09 PM
  #39
cdavy's Avatar
Registered User
T-bolt clamps all around and you will be all set... I spent too many times on the road side fixing popped hoses... Tools are a MUST in the EVO...
Old Apr 27, 2006 | 03:50 PM
  #40
speedracer2169's Avatar
I'm surprised no one asked this but do you have an aftermarket blow off valve. When I had my Type RS it was great for a while. Then my hose blew off. Though nothing of it put it back on. Then it was doing it again. and again so after I lost count how many times I got a t bolt clamp and recirculated it. Worked fine and then the valve went bad. Wouldn't hold boost after 15psi. Took it to greddy because they are up the street from my job and they gave me a new one. Sweet popped it back in and then the hose started to pop off again with the T bolt clamp. Put the JDM MR back in and no more problems. Go figure. Oh and I'm not the only one my friends MR with the same valve had the same stupid issue
Old Apr 27, 2006 | 05:59 PM
  #41
Eggy's Avatar
Link to an easy fix of the IC hose??? I would like to take care of it immediately before starting my trip from Cali to Toronto >.<
Old Apr 27, 2006 | 06:02 PM
  #42
520hpsti's Avatar
Tbolt clamps are a really good investment. i had my IC hose from the throttle body on my sti blow off a lot, a phillips wont get it tight enough, you need something that can ratchet it down or tbolts.
