Odd noise help?
Old Jan 24, 2006 | 01:06 PM
Mortis's Avatar
Odd noise help?
No noise at all when going straight, everything feels fine, sounds fine, tracks fine. Tires are all the same, no wierd marks, wear or anything. All balanced and all that.
Now, when I turn to the passenger side, at speed I/E on the highway going back to the slow lane, or a good speed on/off ramp, I hear this humming noise and feel it ever so slighlty. Nothing major, but it's there and I can tell it's there. No noise turning to the driver side, or at slow turns I can't really tell anything.
Stock suspension, stock rims, never hit anything or anything like that.
Any ideas? Any more info needed?
CV? Wheel bearing?
Thanks guys,
Mort.
Old Jan 24, 2006 | 01:26 PM
awdevoVIII's Avatar
Question
CV? Wheel bearing?
Thanks guys,
Mort.
Weird.... Never heard this one before... Hopefully someone can help
Old Jan 24, 2006 | 01:27 PM
ashton13's Avatar
I think I have this noise too... its hard to hear over the gringing of the TOB though
Old Jan 24, 2006 | 01:50 PM
jfboy's Avatar
Is your suspension all stock ?
Does it do it at low speeed as well ?
Old Jan 24, 2006 | 06:02 PM
Mortis's Avatar
I really do not notice it at low speed, but I'll try to pay more attention to it. Could be I just don't hear it over the usuall intake,tire noise and all that.
All stock on the suspension.
Any ideas?
Thanks for the replies.
Old Jan 24, 2006 | 08:06 PM
shadow4G63's Avatar
weird
Old Jan 25, 2006 | 01:19 PM
Mortis's Avatar
Just one bump to see if anyone else has anything they can add, or have an idea to look for/at something.
Old Jan 25, 2006 | 01:36 PM
gsrboi80's Avatar
Jack up tha wheel move it. Move the wheel up, down, in, out, left, right. See if you get any excess play.
Old Jan 25, 2006 | 01:56 PM
dubbleugly01's Avatar
Being that it only does it in one direction, I'd rule out everything common to both sides, like tire noise since you're running the same tires all the way around (duh!). In my experience, a CV joint will even be noticeable at low speeds, but more of a thunk, that gets progressively quicker in pace as you go faster, but never enough to be a hum instead of just a quick clunk. Wheel bearing on it's way out would be my guess, if it's anything at all.
It could just be road vibration being transferred up the suspension, and finally finding a piece of metal it can vibrate at the right frequency to produce a noise. My car makes a lot of noises that never seem to get worse, and I just chaulk it up to being an EVO.
Old Jan 25, 2006 | 02:23 PM
Greg Haymann's Avatar
With factory tires my evo8 produced the same noise and for a while thought there was a bearing issue. Changed brands and noise went away.
Old Jan 25, 2006 | 04:55 PM
AMX's Avatar
AMX
I've got it too. Started around 30K. Have had it for the last 4K. Only happens on off ramps turning to the passenger side while decelerating slightly or downshifting. I'm not losing sleep over it, the Evo is a pretty noisy car.
