Alignment shop problem?!?
Old Jan 27, 2006 | 07:04 AM
EVIL_EV0's Avatar
Had my car aligned this morning....asking for -1.8 F / -1.5 rear.
They said the most negative camber they could get was -.6 F and -.9 R.
Is there something they may have overlooked to get more camber?
They said it uses excentrics (SP) and it wont move any further.
HELP
Old Jan 27, 2006 | 07:13 AM
HiRevnVIII's Avatar
This is probably the case then. The evo does use eccentrics 9 (cams) to move the camber in and out. Unfortunately there are only two different settings, or ways the bolt can be put in. thus only 2 different camber angle possibilities. Of course your camber will vary by suspension movement over time. The only way to get more camber is to get camber plates, but you may need coil overs to get them, I'm not sure if they make camber plates for stock struts or not.
Old Jan 27, 2006 | 07:17 AM
HiRevnVIII's Avatar
BTW, I am a little surprised they could only get .9 out of the rear, they should be able to get 1.5 as the rear adjustments are a little different.
Old Jan 27, 2006 | 07:58 AM
Jeff_Jeske's Avatar
I feel they should be able to get more out of the front as well. Stock spec is -1 degree with a full degree of adjustability. I am guessing they didn't turn the bolts in the right fashion though I don't know what way the arrows are supposed to be pointing to get max negative camber.
Don't most people get at least -1.5 on the stock suspension?
Old Jan 27, 2006 | 08:14 AM
EVIL_EV0's Avatar
So I had them put the car back on the rack and looked for myself.
There are only two camber settings you can have.
This is set by the bolt holding the front damper to the hub assembly.
There are two bolts on each damper and the top one has an arrow stamped on its head. Arrow IN = -1Deg, OUT = -2Deg. That's IN = towards engine, OUT = towards wheel.
The top bolt is pointing out towards the wheel. So am I fuccd?
Old Jan 27, 2006 | 08:39 AM
HiRevnVIII's Avatar
I'd have to say you might be screwed. Was your car hit? There is now way you shouldn't be able to have more camber in the front. I've never aligned and evo that couldn't be put back in spec.
Old Jan 27, 2006 | 08:50 AM
evo_dadi's Avatar
have you tried going to another shop?
Old Jan 27, 2006 | 09:43 AM
donour's Avatar
The camber bolt has two settings "-1" and "-2". At "-2" I was really getting about -1.4 degrees. My alignment shop wasn't sure how to adjust them either. The easiest thing to do is just take the service manual in with you and show it to the tech. My alignment tech just looked at the directions and was like "oh duh, that's easy", and I was on my merry way.
d
Old Jan 27, 2006 | 09:46 AM
HPF Tom's Avatar
I haven't looked closely but I thought it was a "cam bolt" similar to the Ingalls kits. My alignment shop was able to get 1.25 negative at all four corners so I just assumed this was the case.
Tom
HiRevnVIII's Avatar
If you really want to adjust your camber to what you want, which is probably not possible with the factory adjustments, go here.
http://www.horsepowerfreaks.com/pric.../Camber_Plates
Old Jan 27, 2006 | 09:49 AM
RobDogg's Avatar
So my swift springs can be put on with out camber plates, so i've heard. I'd like to know
if it's still going to have tread problems.
Old Jan 27, 2006 | 09:52 AM
naucrx's Avatar
When I was rolling the stock suspension I had camber set at -1^ F/R. Lowered with Hotchkis springs and front went to -1.6^, rear was adjusted the same at -1^. How on earth do you only have -.6^ Front?!? That doesn't make sense. I also assume you have the stock suspension...
You should be able to get another full degree of negative on the front.
Old Jan 27, 2006 | 10:52 AM
EVIL_EV0's Avatar
Originally Posted by EVIL_EV0
So I had them put the car back on the rack and looked for myself. There are only two camber settings you can have.
There are two bolts on each damper and the top one has an arrow stamped on its head. Arrow IN = -1Deg, OUT = -2Deg. That's IN = towards engine, OUT = towards wheel. The top bolt is pointing out towards the wheel. So am I fuccd?
The car has never been in an accident. I personally verfied the arrow on the camber bolt. Since that is the only option I have to adjust it, I guess I am fuccd unless I lower the car or widen the holes on the strut. The tech did say I could try to remove weight from the wheels, loosening the entire suspension, and then attempt to move the upper strut but that is not considered the norm when doing an alignment.
I don't want to lower the car because it gets tracked alot and I think the stock suspension is perfect for the weekend warrior HPDE guy like myself.
I'm going to look in a rear sway bar. That should help less the understeer I've been getting since I cannot seem to correct it via alignment.
Old Jan 27, 2006 | 10:58 AM
naucrx's Avatar
Yeah, I saw your post about the bolt already being pointed outward. That's crazy... I still can't believe you don't even have 1 degree of negative camber on the fronts.
You could pick up some camber plates from Cusco or Tein for the fronts. They'll run you about $250 and you can set them conservative for the street and aggressive for the track. HiRevnVIII posted a link to buy the Cuscos; Gruppe-S and Z1Auto also sell them I believe. You can get the Tein camber plates at Lancershop if I recall.
Old Jan 27, 2006 | 11:02 AM
MrMejia's Avatar
go to the dealer!
