evo 6.5 emission problems
Old Jan 31, 2006 | 09:20 PM
ralliartevolll's Avatar
im pretty new to this site but im lookin for some help with my evo 6.5 tme i live in new york state and with higher emissions im facing the problem of not being able to get it inspected ive had it on the road and titled in the u.s for the past year or so i was lookin for some help before im faced to run it as a full blown rally car or sell it any help???
Old Jan 31, 2006 | 11:33 PM
Bexa20's Avatar
to my knowledge they do not check for the emissions anymore, they only check if you have CEL light poping out recently, they plug in the computer onto your OBD II and look if you had it. If not you should be good to go. If you reseted the computer you may have to drive it for at least 300 miles until it collects some data. The rest should be as usual.
Old Jan 31, 2006 | 11:37 PM
Bexa20's Avatar
btw, I would love to see your car, where are you located??
Old Jan 31, 2006 | 11:45 PM
badhabit90's Avatar
if youve had it on the road and titled already, why would it be a problem?? just make sure your emissions are okay-e.g. a catalytic converter and the proper OBD2 with emissions for that car for that year. you should be good.
Old Feb 1, 2006 | 01:43 AM
Revolver Ocelot's Avatar
Yea can you post pics? I would love to see a 6.5.
Old Feb 1, 2006 | 10:27 AM
hey thanks for the thought i am running no cat at this time so ill try to that last time i tried to get it inspected from a friend it passed the pre ignition test but it took a while of trying then when we tried the running test it wouldnt even read anything i was thinking cause the car was imported from japan it didnt have the right OBDII any ideas on that?
ill post some pics soon as i can get some on my computer
Old Feb 1, 2006 | 10:39 AM
EVO222's Avatar
if you are running catless but have an o2 sim that prevents you CEL to go on, you should be able to pass inspection here in NYC
Old Feb 1, 2006 | 11:33 AM
tritech's Avatar
was the 6.5 even obd2?
Old Feb 1, 2006 | 04:03 PM
hk2ronin's Avatar
just find a place that does bootleg inspections then you don't have to worry cat or no cat.
Old Feb 1, 2006 | 04:12 PM
Bimmubishi's Avatar
Your car will pass just fine with a cat' in it. Your car is not OBDII compliant. Evos 1-6 are not OBDII. There is no diagnostic port on the dashboard for the OBD tool but the codes can be read with a MUTTII or an analogue voltmeter.
You can read engine codes however. If you're interested in the procedure you can email me at alex at dentsport.com
The engine is the same as the E-8 for the sake of this conversation.
Alex Grabau
Dent Sport Garage
Old Feb 3, 2006 | 11:59 AM
evo 6.5
heres some pics over the summer hopefully they work
Attached Thumbnails evo 6.5 emission problems-novcruise2.jpg   evo 6.5 emission problems-novcruise4.jpg
Old Feb 3, 2006 | 12:16 PM
Nosaj$$MR's Avatar
6.5 in the US and it is titled for road use,how
Old Feb 3, 2006 | 12:22 PM
Evolved Monkey's Avatar
They do check emissions in New York. What you need to do is find a cat-converter that fits and probably some fuel additives made for smog tests just to be sure.
btw, how did you get a road legal TME??
Old Feb 3, 2006 | 12:54 PM
bigfishs's Avatar
NYS emissions consist of sniffer and OBD2 check.
