UR Test pipe Bung position?
Old Feb 1, 2006 | 04:10 PM
MrFairlady's Avatar
OK...I've got a 3" UR test pipe or whatever.. (so he says it is) but there is not a bung for the o2?
now,....Do i need an elbow for it..or what should I do?
1: weld a bung on (where) and do the fouler trick - (if so where does it go- toward pass side near front of car closest to Front flange?)
2: weld an elbow and hope its enough away from the Flow that no cel is thrown?
wanna throw it on but theres no bung (i guess it was supposed to have one??)..so I need to take to a muffler shop & get this done..
Thanks searched but just the main question was : "whats the best"..etc or "cel fix"
thanks
Old Feb 1, 2006 | 04:19 PM
4WS Tuning's Avatar
wait a second....it doesn't have the elbow on it?....if thats the case then i dont think u have UR test pipe...it should already have it on it....call whoever you bought it from cause its not. i've seen this plug thing for 30$...i dont remember what website but it kinda looks like a spark plug or you can get a perrin...
cheers
Old Feb 1, 2006 | 04:20 PM
althemean's Avatar
No bung= its not a UR TP.
SOUTHSIDEITALIA's Avatar
If you have no bung for the sensor, buy the resistor cel fix from buschur or perrin, and be done with it. What exhaust do you have, as you will need to put the sensor somewhere
Old Feb 1, 2006 | 04:21 PM
MrFairlady's Avatar
well for the price I was like whatever...eaiser than having a Muffler shop do it...granted I have to weld a bung on.
I payed like $50 shipped for it.I didn't even thin twice about the bung being there.
so what should I do to make this work i guess is what i need to figure out.
Thanks
Old Feb 1, 2006 | 04:23 PM
althemean's Avatar
either the mechanical fix or the hardwired CEL fix from perrin or buschur....do a search, it will come up.
Old Feb 1, 2006 | 04:24 PM
MrFairlady's Avatar
Heres the deal w/ that.
I have Megan DP and Exhaust that came on the car...planned on the *NEW* Burscher Axle back/rear section (if possible) to replace the ricey Megan Tip/ can that I'm not a big fan of.
so just get the fix and Splice?
Old Feb 1, 2006 | 04:25 PM
althemean's Avatar
you got it. It a matter of dollars as far which one you go with.
Old Feb 1, 2006 | 05:11 PM
Jakeg97's Avatar
that should work ^^
http://www.lancershop.com/customer/p...0&cat=0&page=1
Old Feb 1, 2006 | 05:17 PM
hondafan's Avatar
do a search for mechanical 02 fix in the how-to section, i used it and no CEL. also, i have a UR and they all come with the elbow but you have to cut and lengthen wires for the 02 to reach, so IMO the fix is easier or you can buy the same thing on ebay for $35.
Old Feb 1, 2006 | 05:25 PM
What exhaust came on the car? If you have no bung in the catback, I suggest you get the perrin cel fix or equivalent, because you will have to put the sensor back in for emissions. I don't have a name brand catback, but I imagine they should have a bung after the convertor, for emission purposes?
Old Feb 1, 2006 | 05:30 PM
hondafan's Avatar
look on gruppe-s website under evo exhaust, there's a helix mechanical 02 fix for $13.99. your welcome.
Old Feb 1, 2006 | 05:32 PM
hondafan's Avatar
the bung is to relocate the 2nd 02 out of the exhaust stream so you get no CEL when removing the cat.
Old Feb 1, 2006 | 05:34 PM
You'll still need a bung, put a good find!!!
Old Feb 1, 2006 | 05:37 PM
hondafan's Avatar
i've never seen any evo cat-back without a bung! that o2 fix goes in the stock location on the catback and then the 02 sensor gets threaded into that. VOILA! no CEL without a cat
