UR Test pipe Bung position?
Old Feb 1, 2006 | 05:59 PM
MrFairlady's Avatar
Originally Posted by hondafan
i've never seen any evo cat-back without a bung! that o2 fix goes in the stock location on the catback and then the 02 sensor gets threaded into that. VOILA! no CEL without a cat
Its the Test pipe that doesn't have one.
Ok guys break me down..I'm from an STi...so I can't remember what underneath of my car looks like right now:
header(02)-----cat-----exhaust(02) or how does this go.
header(02)-----cat(02)----exhaust???
so are thier 3 o2's or just 2?
I have a megan (i guess..its 3") DP...then stock cat, then Megan exhaust (that all work fine on the car) what do I need to do.
I'll need to position the bung in the right place on the TEST pipe...in order to use Foulers to back the 02 away from the Exhuast stream?Or pretty much bung it anywhere if I'm using foulers?I read somthing about it had to be toward the passenger side more towards the front of the TP & front of car? whats that about.
Mech fix= fouler trick?
Elec fix =02 sim (which I can't find one on burschur or anywhere.)?
Old Feb 1, 2006 | 06:06 PM
SOUTHSIDEITALIA's Avatar
OK bro, buy the mechical fix from gruppe-s, thread it into where your sensor SHOULD go, screw in the sensor, and drive CEL free. You may need to extend your sensor wiring, but with a stock like setup, I doubt it.
Old Feb 1, 2006 | 06:08 PM
BTW, lancer shop has the perrin cel fix, but it's more than you paid for the pipe!
Old Feb 1, 2006 | 07:05 PM
MrFairlady's Avatar
so thers no 02 in the cat?
I think thats where I'm getting confused.
otherwise if a o2 goes in the cat...just weld in a bung on the test pipe and do the fouler trick.(2 spark plug fouler - 1 drilled out etc Trick?)
Old Feb 1, 2006 | 07:29 PM
hondafan's Avatar
no, the 2nd 02 is in the beginning of the cat-back, where the CEL fix can go that you get from gruppe-s or ebay for $15. there is no bung in the stock cat!
Old Feb 1, 2006 | 08:15 PM
althemean's Avatar
better off just buying the real deal UR TP.
Cutting and soldering the wires is easy, mark them first before you cut.....wrap the ends together (its best to spread the strands of both wires and intertwine them) soak the bare wires in ispropyl alcohol, and then apply the solder. The alcohol acts as a flux, it cleans the areas and draws in the solder. Oh, and be sure to put heat shrink tubing on before you solder to cover the bare connections. Presto...professional install. (not only do I do aircraft sheetmetal, I am also and avionics installer!)
Old Feb 1, 2006 | 08:22 PM
hondafan's Avatar
trust me, threading in the mechanical is much easier, takes all of 5 minutes.
Old Feb 1, 2006 | 08:25 PM
althemean's Avatar
cant fault that...
Bman513
Aug 10, 2016 01:24 PM
RedEvoxGSR
Jun 15, 2010 10:47 PM
Talon_66
23
May 21, 2008 09:51 PM
PlanoEvo
25
Sep 10, 2007 11:30 AM
jemjow
Apr 12, 2006 07:27 AM
