Too much oil
Old Feb 3, 2006 | 01:25 PM
AlohaEvo's Avatar
Originally Posted by SterlingEvo
I think he was referring to the 4th definition:
Noun
*** (plural: ****)
(UK, Aus/UK slang) A cigarette.
(UK slang) A chore; an arduous and timesome task.
(US slang, offensive) A male homosexual.
Note: This is offensive only if used by a non-homosexual person to describe a homosexual male. Homosexual persons often use this term in describing one another.
(US slang, offensive) A jerk, an *******.
Why did you do that, you ***?
(UK (archaic)) term used in UK public schools for a younger student acting as a servant for senior students
(US technical) In textile inspections, a rough or coarse defect in the woven fabric.
exactly what he meant, but notice "US slang offensive"...nuff said and off topic...
back on topic, drain it and DIY from now on.
Old Feb 3, 2006 | 01:44 PM
12mnkys's Avatar
It costs what to change the gasket ring?? 1$? i know a really cool trick if you have a shop vac...change the thing already!
Old Feb 3, 2006 | 02:22 PM
BURNALL_4's Avatar
Originally Posted by kekek
Extra oil in the pan can cause aeration of the oil. With that you lose hydraulic pressure causing damage to your engine!
do like dafarmer said and drain some out!
+1 too much oil is almost worse than not enough. The result is the oil in the crankcase (oil pan) will foam get pumped to the top of the motor (the head) and it loses its viscosity and wont lubricate (thats not good). it will also cause the bearings and rings to not get the correct lubrication and you can start to wipe them out.
pull the filter and dump oil, put filter back on. start it for 30 sec, then let it sit for like 15 - 20 min. check oil, rep. if still to high. get it as close as you can. i would say you will have to do this a max of 3 times.
Old Feb 3, 2006 | 04:45 PM
Evolved Monkey's Avatar
Thx for the advice guys, I took the car back to the mechanic to fix it. He almost got burned when he tried to drain the oil because it was still hot from running. Ended up draining everything and then filling it back up. LoL.
Anyways, he did tell me there was too much soot inside the muffler tip tat wasn't normal. Is it really abnormal or is it usualy for the Evo?
Old Feb 3, 2006 | 04:46 PM
Talking
opps double post.
Old Feb 3, 2006 | 04:49 PM
fsugatorbait's Avatar
This so called mechanic over fills an oil change and then tells you that you've got too much soot in your exhaust. I wouldnt be bringing my car back to him for anything. The evo runs ridiculously rich from the factory, your 'soot problem' is absolutely normal.
SleepySamurai13
Apr 28, 2017 05:04 AM
s84kam
Lancer Engine Tech
10
Feb 8, 2010 03:36 PM
bowlofturtle
Lancer Tranny/Drivetrain Tech
Aug 13, 2008 10:00 PM
lancerko
19
Mar 15, 2006 02:34 PM
JT-KGY
Nov 23, 2003 09:24 PM
