What is this?
Old Feb 5, 2006 | 11:19 PM
conphuzed's Avatar
What is this?
I was looking under my hood just now and noticed this piece just hanging out, without anything running through it like in the picture. So I'm wondering, should something be there, and if not, why do I have it?
Old Feb 5, 2006 | 11:21 PM
evo637's Avatar
I think its an engine tow hook.
Old Feb 5, 2006 | 11:27 PM
poohlvhun's Avatar
that's where you hook up to lift the engine up/out.
Old Feb 5, 2006 | 11:33 PM
AlohaEvo's Avatar
the "thing" running through it looks like an egt sender
Old Feb 6, 2006 | 02:26 AM
Jakeg97's Avatar
lol
Old Feb 6, 2006 | 02:33 AM
4age's Avatar
The thing with the hole trough it is the earthing when you give someone starting help. Check the manual.
Old Feb 6, 2006 | 03:08 AM
smokedmustang's Avatar
Its the Flux-capacitor-relay-junction-sender-wire. (read your owners manual)
Actually I would say something like an EGT probe or something. The manifold is NOT stock, that would have been my first clue! just kidding with you newbie, no need to get upset..
Old Feb 6, 2006 | 03:11 AM
It measures your blinker-fluid levels!!!
Old Feb 6, 2006 | 03:47 AM
Bimmubishi's Avatar
It's an eye hook to use when pulling the engine from the car.
Old Feb 6, 2006 | 04:02 AM
feldguy's Avatar
I dont think you should pick up an engine from an aluminum headed engine with two 10mm bolts securing it. I believe its an earthing spot, but that just may be a joke. I dont know actually, but I do know the piece going into the manifold is an EGT sender.
Old Feb 6, 2006 | 05:28 AM
Sleeper2G's Avatar
yep thats the spot to hook up and yank the engine out, its connected to the block not the head.
Old Feb 6, 2006 | 06:25 AM
Chamama's Avatar
What does that wire/pipe that goes over the engine and bolts on to the cover do? My car does not have that. see pic
Old Feb 6, 2006 | 06:33 AM
Event-Horizon's Avatar
Its the Anti-lag system found on most UK and Japan Evo's. It's also deactivated from the factory.
Old Feb 6, 2006 | 06:38 AM
Chamama's Avatar
But I don't have that wire/pipe (Arrow pointed in the picture) but the USDM evos have them, like in Conphuzed's evo.
(Sorry Conphuzed, for using your pic without asking.)
Old Feb 6, 2006 | 06:41 AM
sharmin7's Avatar
looks like some type of tap for an egt. do you have an egt gauge in your car?
