Need Advice
Old Feb 6, 2006 | 05:57 PM
SKILMATIC's Avatar
Need Advice
Hi I have a 06 EVO 9 and I need advice on how to get this car up to 400whp.
I know there are alot of things you can do get this number but I want to do so without changing the turbo, engine internals(except for maybe cams).
Is this possible? A couple local evo owners told me it was and that the fuel system was good for about 400-450whp. Is that true?
Old Feb 6, 2006 | 06:01 PM
4TUN8's Avatar
Not sure about the fuel system being that good, might want to change the pump....maybe....
280 cams
3 inch exhaust
ported mani
ebay 02 housing
open intake
Alky injection
manual boost controller
reflash
boost gauge
There you go, that should get you 400 to the wheels with 93 octane, or something very close. This would be on a dynojet.....and if it doesn't hit 400 it's about as far as you're going to go on the stock turbo, without nitrous.
Old Feb 6, 2006 | 06:06 PM
SKILMATIC's Avatar
Do I have to get the reflash? And how much does somethign liek that run? Also instead of that could I run a SAFC? And I already have a boost gauge,aem uego, greddy profec eo1, and a greddy tt.
Old Feb 6, 2006 | 06:09 PM
feldguy's Avatar
I dont think 400 on pump will be doable like that...then again Im not sure.
I'd say:
3" Exhaust, Turboback
Intake/Filter/Something to replace the factory box
272 or 280 Cams
Buschur 20G-9 turbo, tubular manifold or Buschur's ported piece (works super well)
800cc or in that range injectors
Flash/ECU
Alchohol injection
Id say pushing the stock turbo that hard will inevitably make it necessary to go for a big turbo.
Conservative tunes on even GT35 turbos yield 400whp marks. Pushing the stock block, which reminds me, ARP headsuds Id say are a must in this case.
Good luck
Old Feb 6, 2006 | 06:23 PM
SKILMATIC's Avatar
Let me ask this. Is the flange to the manifold a t3 flange?
Old Feb 6, 2006 | 06:27 PM
Evoryder's Avatar
...they got cams out for the ix's? don't think so...there is alot of power sitting in cams...whenever they are developed
Old Feb 6, 2006 | 06:37 PM
feldguy's Avatar
Forgot we were talkin about a 9.
Well, Id say wait on the cams....and a MIVEC treatment. Honda users with VTEC have found great power gains when tinkering with that unit.
Either way, 400whp just doesnt pop up, it does take quit a bit of work. With the Evo-9 the way it is with the upgraded turbo, Mivec and such, it might be easier.
Old Feb 6, 2006 | 06:38 PM
SP00LIN's Avatar
You only need to do just two things!
-2.3 stroker kit
-tune
There you go. That's it.
Old Feb 6, 2006 | 06:42 PM
drharlequin's Avatar
-2.3 stroker kit
-tune
and exhaust i would think,
+1
Old Feb 6, 2006 | 06:44 PM
hondafan's Avatar
turbotrix just developed some and hks has them in the works. do a search in TT's vendor forum, there's a thread on em'.
Old Feb 6, 2006 | 06:49 PM
SKILMATIC's Avatar
-2.3 stroker kit
-tune
Please read thread starter for the proper question. thanks
Old Feb 6, 2006 | 06:57 PM
evo8rcr's Avatar
the flash isn't that bad like 200-250 and is good for 15-20 awhp
Old Feb 6, 2006 | 06:58 PM
SKILMATIC's Avatar
^ hmmm and where do I go to get this done?
Old Feb 6, 2006 | 06:59 PM
evo8rcr's Avatar
there are a couple companies dynoflash is a good one they are a vendor on here
Old Feb 6, 2006 | 07:01 PM
evo8rcr's Avatar
http://www.dynoflash.com/indttm.htm
