Some Gtech dyno charts - VIII vs IX
Old Feb 19, 2006 | 06:50 PM
fastevo03's Avatar
For US Spec, curb weight includes all fluid, oil gas etc. Japan spec is dry weight without all the fluids. Europe spec might be same as Japn spec
Originally Posted by k270kmh
I thought that the curb weight = car without any fluids.
btw, the weight of the FQ model was measured at a vehicle balance/scale.
Old Feb 19, 2006 | 10:52 PM
Evo_Jay's Avatar
Originally Posted by jj_008
Here are some plots I made comparing my GT3076 (29psi) to my RX6 (27psi). I use 3600lbs for the weight.
On this plot, which chart is what turbo.
Old Feb 20, 2006 | 06:56 AM
z06fun's Avatar
Nice info. How does the Gtech know the engine RPM, is there a tach input or somethign on it? I'm sure you know also that your curves will be very affected by the the outside air temps and winds etc, so it can be difficult to compare runs on different days
Old Feb 20, 2006 | 08:43 AM
jj_008's Avatar
The red one is the GT3076.
Old Feb 20, 2006 | 08:49 AM
jj_008's Avatar
It gets the RPM pick up from the lighter. On a real dyno, it can be hard to compare runs on different days w/ different temps too. It definitely cannot replace a dyno, but it works well at showing considerable hp/tq changes. You have to use the same road to keep everything consistent though.
Old Feb 20, 2006 | 11:56 AM
madpacket's Avatar
Great info, thanks for sharing. I didn't know that the G-Tech had dyno plotting software, great stuff.
Old Feb 20, 2006 | 03:38 PM
jj_008's Avatar
The SS version will allow you to look at dyno plots and other stuff on the GTech screen, but the RR allows you to import it onto a laptop.
Old Feb 21, 2006 | 06:45 AM
Crufty Dusty's Avatar
Would be nice if you could post up some in-gear acceleration numbers at various speeds, e.g. 30-50 mph, 40-60 mph, 50-80 mph.
Old Feb 21, 2006 | 07:48 AM
jj_008's Avatar
I have only done third gear pulls for dyno runs. The only good number I have, is the 60-80mph, which was done in 1.83 sec. w/ the RX6 turbo @ 27psi. The GT3076 @30psi was around 1.89 sec, but I am not 100% sure on that one since my laptop, w/ the GTech software, screen died.
ArchieBabes
Jul 13, 2014 10:35 PM
is300
Jan 1, 2008 01:51 PM
nj1266
Nov 1, 2007 05:54 PM
ArchieBabes
Jul 26, 2005 08:10 PM
