How can you make an 03 evo more RWD bias?
Old Feb 26, 2006 | 10:22 AM
  #31
x838nwy's Avatar
Some numbers:
'04 Evo 8
Front Toe in: 0+/-2mm
Front Camber: -1deg+/-30mins OR -2deg+/-30mins (max cross camber 30mins)
Caster angle: 3deg55minutes +/-30minutes (max left/right deviation 30mins)
Kingpin inclination 13deg45mins +/-30mins
Rear Toe in: 3+/-2mm
Rear Camber: -1deg30mins (max. cross camber 30mins)
Thrust angle: 0deg +/-9mins
'05 Sti (WRX slightly different)
Front Toe in: 0+/-3mm (Toe angle 0deg+/-15mins)
Front Camber: -0deg30mins (max. cross camber 30mins)
Caster angle: 4deg50minutes
Kinpin incliantion: 14deg50mins
Rear Toe in: 0+/-3mm
Rear Camber: -40mins (max. cross camber 30mins)
Thrust angle: 0deg+/-30min
to whitet777
Old Feb 26, 2006 | 10:25 AM
  #32
x838nwy's Avatar
BTW, if you don't want to be there forever, adjust the camber before you adjust the toe.
Old Feb 26, 2006 | 11:30 AM
  #33
EVOlutionary's Avatar
Originally Posted by sonicnofadz
Change the center differential. I'm not even sure if anyone makes a rear biased center differential for the EVO yet, but I know there are a few made for the AWD dsm. Be careful when doing this. More power going the rear also means more things breaking in the rear.
Cusco makes a 35/65 center diff for the EVO. I've seen it and held that beauty in my hands. Expect to pay upwards of $3500 for it plus some install work.
Alternatively you could get a spool or weld the center diff up to have constant 50/50 split. Watch out for those corners, though!
EVOlutionary
Old Feb 26, 2006 | 11:38 AM
  #34
Jeff_Jeske's Avatar
Hmmm...... Slow in Fast out is better than this:
http://videos.streetfire.net/Player....term=crash&p=1
Old Feb 26, 2006 | 05:59 PM
  #35
Would that be Fast in Dead out?
Or Fast in Stupid out?
I must admit I was impressed with his driving skill and the balance of the car up until the point of impact. I do, however, think that was not the aproptiate place to display said skill. He put other cars and drivers at risk.
EVOlutionary
Old Feb 26, 2006 | 06:01 PM
  #36
BTW, how do I get my car to do that??? (the drifting part, I can handle the crashing part)
EVOlutionary
Old Feb 26, 2006 | 09:43 PM
  #37
7m6m4's Avatar
Originally Posted by hotrod2448
Put wider tires and flared fenders on the front. That will increase front end grip and help make it easier to achieve oversteer. You could put some ridiculously stiff springs in the back but, I don't think that would be a good choice for a road car.
As far as powertrain options I haven't seen anything to give the car a rearward bias.
That is what I did with some Volk CE-28's and its great!
Old Feb 27, 2006 | 12:14 AM
  #38
x838nwy's Avatar
EVOlutionary
I think it was Fast in period. I don't think that qualifies as 'coming out' of a corner. (In any case it was more like stupid in and slightly less stupid out of the car). He was really going quite well... right up to the point of crashing.... anyway, at least he had the *****, I suppose, but i think he should do it somewhere else.
Grimgrak
May 26, 2014 08:31 PM
PCToolsWiki
Dec 19, 2009 06:58 AM
silverscoob
49
Dec 9, 2008 10:57 PM
Stangar
Oct 7, 2005 03:13 PM
neal540
50
Sep 12, 2004 07:57 PM
