Known IX problems?
Old Mar 1, 2006 | 04:44 PM
drharlequin's Avatar
Originally Posted by fimotorsports
mine does the same exact thing
dittto
Old Mar 1, 2006 | 05:16 PM
Doogie Howser's Avatar
+1 with 5k miles
in only 2-3 shift not 4-3 or 5-3 I am going to flush out the fluid soon and see if it makes a difference..
Old Mar 1, 2006 | 05:20 PM
EVOIXMR8916's Avatar
does the mr with the 6 speed alos have problems with grinding gears or not??
Old Mar 1, 2006 | 05:41 PM
su37su's Avatar
I too will like to know if the MR has the grinding problem.
Old Mar 1, 2006 | 06:13 PM
Its hit or miss with evo transmissions, while some shift extremely smooth, others just do not.
I haven't read of an MR having any problems/grinds/resistances but that doesn't mean it couldn't happen.
I think the problem can be greatly reduced if you just flush the transmission fluid, add some shifter bushings, get some motor mounts....
Old Mar 1, 2006 | 08:02 PM
2k6_Evo_IX's Avatar
Registered User
Originally Posted by Rnm
I had grinding particularly if I went from 1st to 2nd if I shifted quick, but I learned to slow it down and no more grinding. Shifts smooth as butter now with 3k miles, but it was really notchy when I first got it.
To me its not so much a grinding from first to second as it is a resistance. Where going from 2-3 is so very nothcy.
Old Mar 1, 2006 | 08:06 PM
SPANKED's Avatar
Originally Posted by yooyooyoo
I don't have a grind but more of a clunk from 2nd to 3rd. I have 11k+ on my IX.
once in a while it happens from 1st to 2nd but only when its cold out (I think).
Same thing here...glad I'm not the only one, it sounds like it's coming from the shifter base not the tranny so who knows. Other than that the car is freaken amazing!!!
I'm gonna try the motor mount and aluminum underhood bushings and see if this fixes the problem...anyone else remedy it?
Old Mar 1, 2006 | 08:07 PM
Evoryder's Avatar
remember guys....push clutch all the way down...when speed shifting from certain gears you need to engage all the way or it will grind...easy fix...i bet you guys don't grind gears going around town?...and continous grinding will result in gate lock out and tranny work...missing gears is bad....either learn how to drive or get a short shifter...
Old Mar 1, 2006 | 08:09 PM
Az3ar's Avatar
very smooth on all gears no problems
Old Mar 1, 2006 | 08:11 PM
lil'evil_evo's Avatar
The IX tranny seems a lot better than my VIII tranny. It shifts so much better plus I have no grinding issues now.
Old Mar 1, 2006 | 08:12 PM
EvoallovEr's Avatar
+1
Old Mar 1, 2006 | 08:22 PM
Stuff's Avatar
9 MR here, no notchiness, no grinding, just a whole lot of awesome.
Old Mar 1, 2006 | 10:45 PM
4g63_24's Avatar
My gears are notchy too...but sometimes they are smooth. I don't know maybe i haven't put enough miles on it yet....Must go drive.
Old Mar 1, 2006 | 10:49 PM
fromWRXtoEVO's Avatar
I can confirm two little issues on the Evo 9 :
Gears are notchy on the 5 speed Evo 9.
Brakes makes noise
I fix the first problem with shyncromesh. I fix the second problem by blasting the brake calipers once a week with my portable gasoline powered 2700psi pressure car wash. I do clean the brakes regularily with high pressure water and degreaser.
Carlos
Old Mar 2, 2006 | 12:10 AM
Evo_Jay's Avatar
Brakes makes noise
Carlos
Yes, the brakes are noisy and even more noisy when dirty. Keeping them clean makes the noise rare.
