Can someone please explain how to ... ?
Old Apr 3, 2003 | 01:05 PM
evo1's Avatar
remove the Lancer badge properly without chipping or F'in up the paint? Thanks!
Old Apr 3, 2003 | 01:06 PM
s4awd's Avatar
Re: Can someone please explain how to ... ?
Use dental floss.
Old Apr 3, 2003 | 01:10 PM
evo1's Avatar
Re: Re: Can someone please explain how to ... ?
Originally posted by s4awd
Use dental floss.
No, really?
Old Apr 3, 2003 | 01:11 PM
Guack007's Avatar
a hair dryer and dental floss usually helps.
Old Apr 3, 2003 | 01:14 PM
evo1's Avatar
So heat it and pull lightly with the floss?? Will is scratch anything on its way off?
Old Apr 3, 2003 | 01:17 PM
eternal9's Avatar
its simply held on with double sided tape. heat it up with a hair dryer to losten the glue and then take the dental floss and saw through the glue. That would be my suggestion. I however have not taken mine off.
TaiwanEvo's Avatar
i dont' want to admit this but i use to steal honda acura signs and GSR vteCHHhh plaques with a credit card... I'm sorry for all the things i have done in the past.. Now i'm grown and i dont' do any of those suff.. Good thing this isn't a Honda acura board..
HobieKopek's Avatar
If it's safe enough to run through your gums....
Don't overheat and becareful with the floss and there should be no damage whatsoever (not even scratches or swirls on a dark car), but if you manage to screw up your paint with dental floss you probably deserve some sort of award.
Old Apr 3, 2003 | 01:20 PM
evo1's Avatar
I'm sure I could find to way to achieve that, moderater ...
Old Apr 3, 2003 | 07:17 PM
SpeedHeals's Avatar
Try fine sandpaper -it might take a while though...
Old Apr 4, 2003 | 11:52 AM
Jonasan50's Avatar
I simply worked the lancer badge up and down, over and over till it came off... Took about 2 minutes... Then used a citric cleaner to remove the glue... Total elapsed time: 3min 47.8 seconds hahaha... That was the simple way of doing it...
Old Apr 4, 2003 | 12:02 PM
DB8GSR's Avatar
Dang you! So you were the one that took my VTEC badge 2 days after I got the GSR brand new back in '99.
Old Apr 4, 2003 | 12:26 PM
smanders's Avatar
I used a hair dryer and dental floss. Came off easy. I then used WD-40 to get the remaining gook off.
Old Apr 4, 2003 | 12:30 PM
BrianDaBox's Avatar
i used a chisel and hammer, came right off
Old Apr 4, 2003 | 03:57 PM
evo1's Avatar
You're freakin nuts!
Thanks guys! ... used a blow dryer and dental flaus & it came right off but I cooked the glue a bit so I used Meguires scratch off, along with a little soap/water and elbow grease to remove the glue.
