wideband o2 sensor hook up help
Old Mar 14, 2006 | 03:18 PM
evilevo2006's Avatar
can anyone tell me where or how far from the turbo i should install my wideband o2 sencor. thanks for the help.
Old Mar 14, 2006 | 04:26 PM
Paulo744's Avatar
In my Supra, I put it about 2 feet AFTER the turbo charger. Works pretty well and the response is quick.Just put it atleast 10 degrees higher than the horizontal(on the tip) so when the car is in the cold start mode, no water will rust it or anything.
It's an easy install, atleast for me it was and you just need to hook up a power and a ground and then run the wires.
Old Mar 14, 2006 | 06:23 PM
32 psi daily's Avatar
24 inches away from turbo.
15 degrees end pointing up, make sure you have enough space for the 02 sensor so it wont knock into the floor panel.
if you have cat, install it before cat.
Old Mar 14, 2006 | 06:28 PM
Ludikraut's Avatar
If you are talking about the tip of the sensor pointing up, then that is incorrect.
I posted a thread of my wideband sensor install over on the Innovate forums: http://www.innovatemotorsports.com/f...read.php?t=442
In a nutshell, your sensor should be mounted as far back from the turbo as possible (i.e. right in front of the cat). It should also be mounted above the horizontal plane (i.e. tip facing down into the exhaust pipe to avoid moisture collecting on the sensor and destroying it).
l8r)
Curt@MrLed's Avatar
Former Vendor
install it next to your second 02 sensor hole..
Old Mar 14, 2006 | 06:56 PM
no tip pointing down, rear where the wires come out, up.
15 degrees, end pointing up
there, comma for you to make it clearer.
Old Mar 14, 2006 | 07:20 PM
Ludikraut's Avatar
Old Mar 14, 2006 | 07:24 PM
ok so i got 18 to 24 inches from turbo. thanks guys for the help.
Old Mar 14, 2006 | 07:25 PM
24 inches + is what you want.
but it gets a bit difficult if you go too much back.
You want it near where the stock 02 sensor goes into the passenger side floor panel, where there is a hole in it already.
Old Mar 15, 2006 | 01:02 AM
Jakeg97's Avatar
i have read 18inches away from the turbo. but right at the end of your downpipe is your best bet
Old Mar 15, 2006 | 05:43 AM
downpipe, you'll burn your 02 sensor out quickly with bosch sensors, unless you get the $200 02 sensor. But eventually they'll burn out too being so close to the turbo.
Old Mar 15, 2006 | 05:54 AM
sparky's Avatar
Can the O2 sensor bung be mounted in the cat delete or in a gutted cat?
Old Mar 15, 2006 | 05:57 AM
you could get plx device wideband and it'll replace your stock 02 sensor.
Old Mar 15, 2006 | 06:03 AM
nothere's Avatar
perfect place
Old Mar 15, 2006 | 08:23 AM
Ludikraut's Avatar
Mounting your wideband sensor at the end of the downpipe should be fine, unless you're running really high EGTs. In that case a heatsink (like this: http://www.innovatemotorsports.com/x...cat=250&page=1 or homemade) can help. If you're running catless, then you could mount the sensor further down your exhaust pipe.
l8r)
