Cold Idle question
Old Mar 17, 2006 | 04:57 PM
fransevo's Avatar
Cold Idle question
I have done some research but didn't quite get an answer. When I start the car, the first 4-5 mins runs horrible! It will stall quite a bit and if I try to drive when itisn't completely warmed up it buck and fart. Could this be ECU related?
Old Mar 17, 2006 | 06:19 PM
Agent-Smith's Avatar
Its related to the cams. My 280's give me **** when its cold out as well. I just hold it at 2k for a while to warm it up.
Old Mar 18, 2006 | 05:38 PM
Olde Evo's Avatar
Even without cams, Evo's take a few minutes to warm up before running smoothly. I let
mine idle a minute or two before taking off.
Old Mar 18, 2006 | 11:44 PM
roadace's Avatar
My idle is fine and I have 272s. Runs perfectly... no fuss even in the cold. A warm-up period is always good.
However, I still had my stock BOV (plastic) when I did my dyno pulls and it was leaking very badly and my idle then was very rough. I switched to an Evo IX BOV and it fixed the idle. It also holds much more boost.
You could have a leak somewhere and it's throwing the Airflow sensor off. Try checking all hoses and vacuum lines too.
blueprint
Mar 27, 2017 11:29 PM
Buguy
Oct 19, 2012 05:07 PM
Xearo
Mar 10, 2011 10:47 AM
Tnnrx7
Site Feedback / Suggestions
11
Jan 26, 2009 02:34 PM
stuntman
Nov 26, 2008 09:17 PM
