Clutch advice
Old Mar 19, 2006 | 05:54 PM
  #31
jrsimon27's Avatar
well i guess iam lucky
  #32
turbotool's Avatar
Originally Posted by LITE SPD
Maybe they should take the 100,000 mile warrenty away from the Evo. Might make the car cheaper. You are right, they are very reluctant to cover the drivetrain. I see this every time an Evo comes in for a major repair.
Mine only came with a 3/36000 and i bought a 6/72,000 when I purchased the car used.
Old Mar 19, 2006 | 05:55 PM
  #33
LITE SPD's Avatar
Originally Posted by Tpayne84
A dynoflash is undetectable by the dealerships.
Thats not true, a Mitz tech can see that parameters and values have been changed from stock ones. Its alittle tedious work for them but it is possible if they were told to check by Mitsubishi. Mitz reps are very aware of flashing the stock ECU to make power. Its almost like they went to a training class specifically on the subject of Evo modding.
Old Mar 19, 2006 | 06:57 PM
  #34
turbotool's Avatar
Btw, is this the real deal???http://cgi.ebay.com/EXEDY-STAGE-1-OR...QQcmdZViewItem
Old Mar 19, 2006 | 07:05 PM
  #35
TTP Engineering's Avatar
Originally Posted by turbotool
Alright, here's the deal. My clutch just recently started slipping BADLY. I have approx. 300whp and was wondering what the capabilities of the stock clutch were. If the stock unit can't hold much more than that then I have to get an aftermarket performance clutch. The only problem is it will probably void my warranty coverage on the tranny and the transfer case. My other option is to buy a new stock clutch and hope it holds up because I plan on making more power. So what should I do?? And I'd appreciate any reccomendations on aftermarket clutches that are comfortable and a step above the stock clutch.
445.1 torque held fine on stocker @ 33psi on stock turbo.
Old Mar 19, 2006 | 07:12 PM
  #36
Tpayne84's Avatar
it looks like you'll ether need to resurface your old flywheel or just buy another also.
DAMN 33psi on stock turbo how.. i thought it maxed out at like 28 or something like that??
Old Mar 19, 2006 | 07:14 PM
  #37
MattGold's Avatar
That's an Exedy Stage 1 Organic. Similar to the ACT HDSS clutch.
This is NOT the same as an Exedy Twin Plate people talk about.
I recommend the Twin hands down. Best money you can spend on your car, period.
Old Mar 19, 2006 | 07:15 PM
  #38
turbotool's Avatar
Yeah I know that. I was just making sure its a REAL Exedy clutch.
Old Mar 19, 2006 | 07:16 PM
  #39
Danny23's Avatar
is that the excedyHD twin your talking about? (HD)
Old Mar 19, 2006 | 07:18 PM
  #40
turbotool's Avatar
I'm not sure. It just says Stage 1 organic clutch.
Old Mar 19, 2006 | 07:21 PM
  #41
Tpayne84's Avatar
the exedy twin is on this page : http://www.gruppe-s.com/Evo/evotrn.htm
Old Mar 19, 2006 | 07:23 PM
  #42
turbotool's Avatar
Yeah, I'm not talking about the twin. The one I'm talking about is also on that page.
Old Mar 19, 2006 | 07:26 PM
  #43
Tonykwok's Avatar
I recommend getting the exedy carbon hyper single. There's no need to get twin unless you are serious track/autocrossing/drag-racing.
Try to get a "carbon" clutch. You will be amazed
Old Mar 19, 2006 | 08:15 PM
  #44
I did not think the carbon hyper was even released in the states yet. Maybe Matt can expound on this.
Old Mar 20, 2006 | 09:09 AM
  #45
hel_if_ino's Avatar
Yeah, this is the one I currently have, exedy organic with a 3100lb pressure plate, and fidanza flywheel, works great, a little noisey, but other than that no qualms.
