weight of intercoolers
Old Mar 25, 2006 | 08:50 AM
BURNALL_4's Avatar
Originally Posted by nothere
in an attempt to balance power and control any addition of weight to the front of the car needs to be well thought out.
adding twenty lb to the very front of the car has disadvantages too.
you will never notice the extra weight, because of the power differerce that you will gain from it......
Old Mar 25, 2006 | 10:19 AM
EVOSlayer's Avatar
Originally Posted by 13-0
No its the other way around. You want to Exchange heat not retian it.
I get what you're thinking is here but a lighter intercooler (especially a tube fin like the stocker) will heat soak much faster and will not cool as well as the heavier bar and plate designs of most aftermarket FMICs. You're right about a larger core retaining heat longer once it reaches heat soak but many of the larger FMIC's on the market rarely ever get to that point for a number of reasons (surface area of the core, material, cooling efficiency, etc...)
Old Mar 25, 2006 | 11:15 AM
SlowCar's Avatar
in any kind of heat exchanger, you want to maximise the surface area, minimise mass/material. you want to get rid of heat..therefore lighter, less thermal mass is better.
Old Mar 25, 2006 | 10:54 PM
EVOSlayer's Avatar
A lighter FMIC will allow it to heat soak much faster. The heavier the FMIC material is enables it to resist heat soak much better. Unless you plan to pre-heat your FMIC then a heavier one will function much better. If you have a large surface area and a heavy FMIC, chances are you will not soak the FMIC.
Old Mar 26, 2006 | 12:33 AM
Boosted GP's Avatar
Then you will be taking advantage of it. I need one now myself.
Which one will you be getting?
rebel
May 22, 2010 03:17 PM
EVO8LTW
ExtremeTurboSystems.com – WA
Sep 6, 2008 08:58 AM
turbo26tsi
Jul 3, 2008 08:53 PM
MR 600
44
May 22, 2007 10:37 AM
whitet777
Mar 29, 2004 08:33 PM
