Exhaust manifold is Stainless
Old Apr 6, 2003 | 09:26 PM
Alfriedesq's Avatar
Just an interesting factoid i discovered while drilling in a EGT bung - after dealing with cast iorn subaru crapola manifolds it was nice to see a real stainless exhaust manifold - did not take it off to see how smooth it was inside and if some porting would help - but I was thinking it would be nice to ahve it ceramic coated?
Old Apr 7, 2003 | 12:40 AM
STiDreams's Avatar
How thick is the SS? Will it hold the probe without welding on a bung?
Old Apr 7, 2003 | 12:51 AM
superz's Avatar
um, sorry. That's a cast iron manifold, just like every other manufacturer. What made u think it was SS?
Old Apr 7, 2003 | 01:41 AM
wrx-vs-evo's Avatar
probably the genius at pruven told him
Old May 23, 2003 | 09:25 PM
WRX1832's Avatar
Al,
If you did not remove the manifold how did you install the egt? Did you drill with the motor running? I am in the process of doing it myself but am haviung a tough time removing the manifold.
Thanks!
Old May 23, 2003 | 10:38 PM
Alfriedesq's Avatar
Yes - I just drilled it with grease on the threads of the drill and with engine running
Old May 23, 2003 | 10:52 PM
mrdecibel's Avatar
I would reccommend removing the manifold. Very easy to do. Toughest part is removing the two studs on turbo. Double nut them to remove them. You will need to go to the hardware store and get some metric nuts to do so. While you are there replace the studs with bolts for future turbo area upgrades.
Old May 23, 2003 | 11:15 PM
Alfriedesq's Avatar
Great idea ! So you're saying just leave the turbo in place and pull the studs out and the manifold comes off?? How hard is it to reach the studs on the manifold with the turbo in ?
Old May 24, 2003 | 06:52 AM
Jonasan50's Avatar
Well the 1G turbo DSM's were cast iron... But the 2G DSM's were indeed stainless steel... That's probably why the EVO exhaust manifold is also steel... That's why 99% of all DSM guys upgrade the exhaust manifold to a 2G DSM... You can port it and not really worry about it cracking, like the crappy iron ****...
Old May 24, 2003 | 08:19 AM
travestyevo's Avatar
Thats funny, on my 1G Talon when I swapped it too a 2G manny, the new one was also cast iron, and my 99 GSX, with all of it great stock power has a cast iron manny. I didn't think they poured SS into casts? did they? I thought SS only came in sheets and pipes.
Old May 24, 2003 | 08:43 AM
OX's Avatar
OX
My 2G DSM manifold was not stainless either. It rusted over pretty well. My EVO manifold is rusting already and has only been driven in the rain once and washed twice.
Old May 24, 2003 | 10:27 AM
Jonasan50's Avatar
It's not polished stainless steel... It's whatever it is.. The mainfold is steel, not cast iron.. The steel won't crack.. The maifold on the 1G DSM's will crack.. 2G DSM don't... The EVO, won't...
On my wrx, I have polished stainless steel headers.. They are rusting on the surface.. But it won't rust through or crack..
Old May 24, 2003 | 04:58 PM
WRX1832's Avatar
What temps are you guys seeing at idle/cruise/wot? Please specify if your car is modded.
Thanks,
Mike
Old May 24, 2003 | 07:36 PM
broken's Avatar
just to clarify, ALL 1g and 2g dsm's, amd ALL evo's use a CAST IRON manifold. You can indeed cast SS but due to cost not too many will do it. The 2g manifold has bigger runners and thicker walls that is the sole reason people swap 2g mani's into 1g's.
