A/C button no longer works
Old Mar 25, 2006 | 12:16 PM
cdavy's Avatar
Registered User
Question A/C button no longer works
I recently changed my head unit and now my A/C will not work... The A/C light does not come on and the A/C does not work in the MAX position... I was very careful in taking things apart... I guess I could have messed something up, but can't see it... Anyone else experience this?
If I have to replace the HVAC controls, anyone know the costs? Ideas?
Old Mar 25, 2006 | 01:01 PM
BADEVO's Avatar
Check FUSES first...... Dont jump to conclusions...pace yourself
Old Mar 25, 2006 | 01:08 PM
Chewie4299's Avatar
check fuses and make sure you didnt accidently knock out the plug benind that switch. The first time i did a headunit in my old lancer i ripped the whole dash apart because i didnt know how it all came together. Now after doing the same thing like 10 times between my old lancer and evos i know it only takes two screws and voila the right piece comes off. I say this because the first time i did it i took it all apart and forgot to plug something back in when putting it together. something didnt work right and i had to take it all apart again.
All i can say is THANK THE LORD that our dashes are 10000000000x times easier to work with than a civic's. I did a headunit in my friend's car and that alone was like 3 hours of work. i HATE civics.
Old Mar 25, 2006 | 02:00 PM
cdavy's Avatar
Registered User
Thanks for the advice. Not sure why I would not have thought to take a look at the fuses!
I started looking at the work involved in doing a swap with the Gallant or Eclipse as I have been reading all about the relocations and HVAC swaps (an excuse to go down that path and try the JDM auto climate impossibility)... Still think this has to be possible to workout...
I started thinking too complex and forgot the simple stuff...
Fuse would be cool!
I will take a look and report back.
Old Mar 27, 2006 | 06:38 PM
cdavy's Avatar
Registered User
So, I have checked the fuses under the hood and they are all fine...
I also moved the relays around with no luck. I guess I did not jump to conclusions after all. Ideas? Anyone know the part number and cost of the HVAC controls? I will go to the dealer and see what I can find.
Old Mar 27, 2006 | 07:14 PM
Chewie4299's Avatar
did you pull your dash apart again and check that you didnt disconnect anything by accident?
Old Mar 27, 2006 | 08:10 PM
cdavy's Avatar
Registered User
Yeah, besides everything else works, recycle and defrost...
Old Mar 28, 2006 | 01:16 AM
BADEVO's Avatar
Yeah how bout taking a relay and replacing the AC one first. A lil cheaper then HVAC unit I am sure. Hopefully that helps you some, cuz I know mitsu is gonna bend u over backward for one. OH hey wait just thought of this, make sure your black plastic AC button is lined up right in the panel and it makes contact with the little switch on the circuit board too.
Old Mar 28, 2006 | 07:48 AM
speedjunkie2003's Avatar
theres gotta be a loose wire of some connection that got nocked off, you jsut gotta find it, i have taken my interior apart SOOOOOOOO many time for mods, removing replacing, upgrading...etc, just get in there with a mini mag light flashlight and take your time...
Old Apr 19, 2006 | 05:51 PM
cdavy's Avatar
Registered User
So I fixed this... I had to replace the contols, got the entire setup form ebay motors for 100 bucks shipped and all is good...
KillaYayo
Aug 31, 2016 10:47 AM
evokid511
Apr 7, 2010 03:27 PM
Kracka
Oct 3, 2009 04:13 PM
gzzza8181
Lancer Aftermarket Forced Induction Tech
10
Dec 29, 2008 09:08 PM
fkw958
Feb 6, 2008 11:09 AM
