Can you screw up intercooler pipe replacement?
One of my employee's said he used to work in a body shop and can install my new Helix Intercooler pipes for $100. Does this require a mechanic or should he be able to do it knowing how to take the bumper off?
Thanks
Thanks
That im not too sure of, but I'm sure it is posted on here somewhere. I would be interested to find out myself because I'm not feeling much difference since I installed my AMS LICP. Maybe I have a leak... who knows.
Originally Posted by AC556k
Thanks,
How do you check for boost leaks?
You shouldn't feel too much of a difference. The only thing you will probably notice is faster spool. It's like adding a K&N panel filter, I'm sure there is some power gained but you dont feel it.
Originally Posted by Kee1pride
installing the upper ic piping is no fun though
Originally Posted by EVOL EDO
upper is easier than lower u just may have to smash it a little to fit with the stock battery, lower requires removal of the starter to change the turbo outlet pipe, also dont forget to use a high temp gasket sealer my outlet pipe was leaking until i did.
Originally Posted by dsmfan95
Maybe Evo9's are different, but I didn't have to remove my starter.
