Megan Racing TBE
Originally Posted by TTP Engineering
Nice work Dr. SS.
We have used this TBE to over 400whp last yr. Currently at about 475whp, just need to visit the dyno.
I have a few turbobacks, testpipes, O2 housings, manifolds and catbacks in stock.
PM me if anyone is interested in a special deal on the catbacks alone. These are the new versions just like Dr. SS with the redesigned rear hangar.
Hmm 475.... Scott can you please tell me what you installed in the past few weeks... Im dying to know!!!
I have the older version of this TBE on my car and just like Broeli above -- i always get compliments on the sound of this exhaust. For the money, you can't beat this exhaust!
Oh, I wanted to add on Zeus' comment above. My existing turbo-back used to be on my 04. Since I no longer own that car and now own the 05 I did use the existing exhaust. This exhaust did fit but it's a bit tighter than I had hoped -- however, i do not have any rubbing or noise issues.
I have a full Megan TBE and I love it. Sounds AWESOME at WOT..its a great ripping sound.
However I need put the aftermarket gasket in, I just left the stock one on, and bolted up the dp, and I think it leaks a little bit...my bad
Im also running this TBE on my GSR. LOVE IT!!!
No drone.
Clean Sound
Gets a lot of compliments
Chicks dig it too.
My one issue... every now and then i get the sound like its rubbing on my drive shaft. ITs only once in a blue moon though. My mid pipe o2 faces the outside of the car.... and everything it nice and tight, and doesnt move. Any ideas? even though its only once in a blue moon.... it did it one time when some girls were around. How fresh can your evo be, with the exhaust is rubbing the drive shaft aye? haha.
No drone.
Clean Sound
Chicks dig it too.
Originally Posted by High_PSI
Any Updates on the IX Megan Exhaust being remade?
Megan has been threatening a price hike when 06' model production is full swing... However, I suspect that won't happen until the downpipes are ready. Since they ship separately anyway, You might want to jump on the catback while you can. The next shipment should be ready to ship Monday or Tuesday.
Originally Posted by Dr. SS
test pipe, resonated with full 3" ID
d
Originally Posted by donour
Is this installed correctly? I wouldn't think that they'd put the rear 02 bung below the horizon. It's bad for the sensor and it'd probably get damaged from road debris.
d
d
Originally Posted by Liquid-R1
Are you running a 04? And is that Megan's full exhuast? If so, no, that's incorrect. You need to rotate the mid-pipe 180 degrees and attach the O2 bung to the hole on the test pipe... Otherwise, the exhaust won't line up. You'll run the mid pipe close to the driveshaft and the metal part of the fuel tank. And if you try to correct that by moving the exhaust bracket over to the other side, you'll end up touching your bumper and melting it...
Your PM has been returned.
