Is this oil ok to run in my rear diff, X case, tranny?
Old Apr 3, 2006 | 11:40 AM
EVOIX4me's Avatar
Ok so i replaced my rear diff fluid with royal purple max-gear oil 75w90 it says it has a limited slip additive and meets gl-4 , gl-5 requirments. Anyone have this in their evo and what is your thoughts on this oil? I plan on also putting it in mt transfer case and transmission
Old Apr 3, 2006 | 11:50 AM
elhalisf's Avatar
Gears, jon at TRE, says do not use fluids that will meet both GL-4 and GL-5 requirments. only use fluids that are specific to one of them.
It will probably be ok to use in your t-case and rear diff, but no way in the trans.
however, i would not run anything other than the oem diaqueen fluids in the diff/tcase.
Old Apr 3, 2006 | 12:09 PM
inco9nito99's Avatar
Careful what kind of gear oil you use because Mitsubishi WILL void your warrantee (depending on what dealership), if something breaks and that part used a fluid not recommended or approved by Mitsu.
Old Apr 3, 2006 | 12:13 PM
EVOIX4me's Avatar
Yea i dont wanna void my warranty, however i am looking for a better fluid that stock or is there any
Old Apr 3, 2006 | 12:22 PM
Az3ar's Avatar
Again and again...
Its been posted 92472394737437484787198479874891798472 times
Diaqueen in your diff and TC
Syncromesh in your tranny
Royal will damage your TC and diff
Old Apr 3, 2006 | 12:33 PM
EVOIX4me's Avatar
Is diaqueen a brand of oil or an oil type ? Is there anywhere to get it besides the dealer?
Old Apr 3, 2006 | 12:35 PM
gsrboi80's Avatar
Diaqueen and syncromesh in my cars. Jon @ TRE talked to me for a half hour about using these fluids strictly. Hell be getting my buisness com rebuild time
mayhem's Avatar
My God! Search son!
Old Apr 3, 2006 | 12:36 PM
Warrtalon's Avatar
There is nothing better than the stock Mitsu OEM Super Diaqueen LSD Oil for your t-case and rear diff. Why would you want to randomly change that stuff? It comes from Mitsu, but some places re-sell it like Lancershop.com . In the tranny, you can upgrade to BG Synchroshift I or something like Syncromesh.
Old Apr 3, 2006 | 12:49 PM
EVOIX4me's Avatar
Ok done i called the local mitsu dealer its 46.00 for 4 litersof the diaqueen i think thats what he said anyway since i ran the royal purple in my car for about 200 miles do you think i caused any damage ?
Old Apr 3, 2006 | 12:50 PM
Warrtalon's Avatar
Hopefully not.
Next time, ask BEFORE doing it, not after...
Old Apr 3, 2006 | 12:51 PM
Az3ar's Avatar
We dont know. Just change it ASAP.
Good luck
Old Apr 3, 2006 | 01:01 PM
Erik@MIL.SPEC's Avatar
Originally Posted by Az3ar
Again and again...
Agree on Diaqueen in the TC.
With MR's, I disagree with you on the Synchromesh or BG Synchroshift. I have been underwhelmed with the BG. I recommend Castrol Syntorq, which is available under a different name at Dodge dealers (and GM too I think). The Mitsu manual states 75-85 GL-4 or EXACT equivilent. The part number for mopar dealers is 04874459. It's a black bottle labled mopar synthetic manual transmission lubricant SAE 75W-85, on the back it states it's for the NV4500 tranny and that it's GL-4. This information was passed onto me by another MR owner here who didn't like the Synchroshift either.
I have been running redline in my rear diff for 12,000 miles with zero problems. It is certainly safe to run Mitsu fluid in there too.
Old Apr 3, 2006 | 01:49 PM
Kee1pride's Avatar
i've been having trouble with my 3rd and 4th having tension pulling them in and out if i an being gentle or going back to neautral. if i shift fast the clutch grabs perfectly fine and i dont feel the tension but still i know its there and it scares me
i put in some syncromesh this weekend and it hasn't helped anything :<
Old Apr 3, 2006 | 01:52 PM
Try the Dodge stuff and give it a few hundred miles...or put OEM fluid in.
