Has anyone had their Greddy Turbo Timer go bad?
Old Apr 3, 2006 | 05:54 PM
spudlus's Avatar
My TT has been installed for a while and working fine. Now occasionally I shut the car off and the TT counts down as normal however the car shuts off immediately when I turn the key. Another time things work perfectly. I have checked all the wiring through and through and can't find anything wrong. I'm using a harness. Any ideas?
Old Apr 3, 2006 | 06:50 PM
NIevo's Avatar
I had the same problem with mine and had to do a line switch reset. If you still have the manual it is on page 27. If not go to Greddy.com, click on "tech" and you can download the manual from there. Hope this helps.
Old Apr 5, 2006 | 12:42 PM
spudlus's Avatar
NIevo, thanks man, amazingly it worked. What's weird is that I never changed or played with any of the settings. I was a little skeptical at first but thus far all seems to be working well and normal.
Old Apr 5, 2006 | 01:13 PM
NIevo's Avatar
Glad to hear it worked for you. Im not sure how mine got switched either but it took awhile for me to figure out how to fix it. Everyone kept telling me that my e-brake connection was wrong or the unit had gone bad. Now I just need to figure out how to wire in the speed sensor wire
Old Apr 6, 2006 | 03:31 AM
spudlus's Avatar
Unhappy It started again
Would you believe that it started doing it again? It just seems to be intermittent with no definate cycle of when it happens? I don't have the e-brake hooked up but it has been working all this time. Any more ideas?
Old Apr 6, 2006 | 04:27 AM
smokedmustang's Avatar
I have the same problem. but since I took out my center cup holder deal, I can see the wires where it is connected. It will work normally now, and when I put a cup of coffee on the "wires" it will shut off immediatley. so it is a connector problem for me!!
Old Apr 17, 2006 | 10:27 AM
spudlus's Avatar
It would appear that the issue is on the circuit board. Try as I may I can't find a harline crack or anything resembling one but when you apply a little pressure it works and when you release it stops. I've soldered all the wires that I can, thinking it maybe a loose wire but no avail. I have simply open the case and propped the circuit board until I can order a new TT. Thanks for the help guys.
beast66
Feb 15, 2016 12:51 PM
03lan-evo
15
Apr 11, 2009 12:36 PM
shmaa
11
Jan 23, 2007 08:26 PM
byc_panty
Oct 27, 2006 12:54 PM
Derek888
15
Nov 28, 2005 12:04 AM
