Floor Jack Slipped... Big Bump in Floor Now
Old Apr 5, 2006 | 08:49 AM
  #31
Links0000's Avatar
Good luck on banging the hump out. Just be thankful you werent injured in any of this. I've actually had a car fall on me because I was to stupid to use jack stands. The car flew down squishing my head with the front bumber (thankfully not the engine or tranny) a little before rebounding back up. Lets just say I had a bit of a headache and scare after that .
Old Apr 5, 2006 | 08:52 AM
  #32
Spooldyou's Avatar
i wouldnt sayt hat one problem leads to another. Maybe your just not jacking it up in the right place. You cant just throw the jack under the car and start cranking be careful when working on your car. The last thing that we wanna hear is that one of our members got murdered by his EVO Due to improper use.
Old Apr 5, 2006 | 08:56 AM
  #33
ksuchewie's Avatar
I'm glad your safe. I had a similar experience last fall. Scared the crap out of me.
Old Apr 5, 2006 | 08:59 AM
  #34
Kings Fan's Avatar
That really sucks. I've never had a car that has its jack up points get chewed up from a floor jack. So I started using a block of wood instead... Now what if it slips?
  #35
lexat20's Avatar
Me too just a few weeks ago. I was changing my wheels on my escalade and it fell. I was just about to pick up the wheel to put it on and the jack flew right by my leg and scared the **** outta me. I actually took a step back and waited about 15 minutes to calm down b4 I picked it back up. No damage to anything but my garage floor fortunately. Could have been a disaster. Glad to hear you are ok. Cars are always repairable
Old Apr 5, 2006 | 09:04 AM
  #36
deadbeatrec's Avatar
find something else other than wood to displace the load more equally. maybe a thick peice of rubber. that works for me.
Originally Posted by saw22
Im drawing a blank this morning with terminology for some reason. You know the metal bar that runs from front to back under each side of the car (about a foot under the car or so). I was jacking on that to get the front-left part of the car off the ground (to get to the bottom of the UICP). The block slipped off that and made the jack land under the floor board itself. The car dropped about, what, 2 inches?
Old Apr 5, 2006 | 09:45 AM
  #37
smp3000's Avatar
That happened to me with my last car. I was using a wooden block to raise the car higher and when I went to lower it the block broke and the car dropped 3 inches back onto the jack.
Not only did it cause a big bump under the car but it shattered my rear window. Luckily my insurance company bought my story about a rock hitting it or I wouldv'e been out about 900$.
Old Apr 5, 2006 | 10:10 AM
  #38
letMeIn's Avatar
damn . Good thing u weren't under the car.
Whenever I lift my car with a floorjack I use 2 x 6 ton stands on the sides and 2 x 3 ton jack in the middle. The front is on ramps ofcourse. I know its an overkill , but would rather be safe than sorry.
good luck
Old Apr 5, 2006 | 02:50 PM
  #39
saw22's Avatar
Alright, I just got done beating the hell out of the dent in the floor . Nothing fancy, I just took a good sized board and beat on it. I had better ideas if that didnt work well, but it did. It's not perfect, but 100 times better than it was. I had one of my friends sit in it and tell me if it seemed odd to him.. "Nope". Works for me.
Thanks for all the replies and concerns. Now if I can get over my fear of dropping the car again, Ill be doing alright
Old Apr 5, 2006 | 04:33 PM
  #40
EVOlutionary's Avatar
Sorry to hear about your misfortune. I had a similar incident. I was jacking up my car using the front tow hook as the jacking point. The jack slipped forward off the hook and went right up through my intercooler. Luckily the IC was the only think that was broken, and because a stock replacement is so expensive and I have a cool insurance company, I am now an owner of an AMS intercooler.
EVOlutionary
Old Apr 5, 2006 | 05:33 PM
  #41
Evo_Jay's Avatar
Originally Posted by stevEVO8
Use the jacking points in front and rear and not on the side of the car. I use Rhino ramps for the front most of the time and then jack the rear up and use the stands.
+1
ALWAYS use the front and rear jacking points when useing a floor jack.
The side spots are ONLY for the factory jack.
Old Apr 5, 2006 | 09:03 PM
  #42
bullfrg's Avatar
Deja vu, I had this exact thing happen to me last year same spot and same issue (board on jack). I ended up taking mine to a body shop for repair. They pounded it out and spot welded along the frame rail as it had caused it to pull away a little.
Old Apr 5, 2006 | 09:24 PM
  #43
DCD's Avatar
DCD
Be careful out there guys down here in NZ a guy got killed a few weeks ago when a car he had jacked up and was working on fell on him.
Be safe everyone!
Old Apr 6, 2006 | 07:27 AM
  #44
Uncle Boo's Avatar
What are these "front and rear " jacking points? My owners manual only shows the side jacking points.
Old Apr 6, 2006 | 07:38 AM
  #45
Fluid1's Avatar
This is why I bought ramps. If I don't have to take a wheel off, I don't use a jack. And if and when I use one, it's a nice Kobalt one, with a large holding surface. You are never better than your equipment.
