Floor Jack Slipped... Big Bump in Floor Now
Old Apr 5, 2006 | 04:12 AM
saw22's Avatar
My EVO is beginning to remind me of my old DSM... one problem leads to another. I jacked the car up Saturday to replace a couple clamps on the UICP with t-bolt clamps (which were too big, by the way). I used a floor jack on the driver's side, with a block of wood like I always do. I had the car up a few inches, still not very high at all, and just as I was about to put the jack stand under the car.. BAM.. the block slipped and the car fell from the rail (cant think of the right term) to underneath the floor board itself. It scared the crap out of me to say the least. Two seconds later I would have been under there with the jackstand and who knows how that would have worked out.
At any rate, now I have a damn raised spot in my floorboard where the jack landed, right about where my left foot sits if Im sitting up straight. Its irritating as hell. Any one ever had this happen before?
Im gonna try to pound it back down later today. Hopefully that will work, else it might be in the body shop.
Old Apr 5, 2006 | 04:15 AM
TheGVR4kid's Avatar
It's a speed dimple.
Old Apr 5, 2006 | 04:20 AM
EVOclub4's Avatar
glad that your safe......ouchy for the car
Old Apr 5, 2006 | 04:24 AM
saw22's Avatar
Thanks. I dont know what's worse, what happened to the car or the fact that now I get a crappy feeling thinking about raising it up again. Kind of like losing trust in a good friend Oh well, I guess its like getting a speeding ticket. "Ill never speed again.. this sucks" One week later...
Old Apr 5, 2006 | 04:31 AM
nhsean69's Avatar
Just be glad it was your floor board with the dimple, and not say......oh......Your leg or somethng. I personally never use a block of wood, cause you lose the security of the cup on top of the jack. I also, keep the jackstand next to me when i jack the car up so i can immediatly place it under neither the car. Sucks about the floor board, but im sure you can knock it down to the point where its not to noticable.
Good Luck, and be happy your safe!
Old Apr 5, 2006 | 04:35 AM
j3ffw19's Avatar
sorry for your luck
Old Apr 5, 2006 | 04:47 AM
deadbeatrec's Avatar
one question, where were u jacking that is next to where ur left foot sits?
Old Apr 5, 2006 | 04:55 AM
saw22's Avatar
Im drawing a blank this morning with terminology for some reason. You know the metal bar that runs from front to back under each side of the car (about a foot under the car or so). I was jacking on that to get the front-left part of the car off the ground (to get to the bottom of the UICP). The block slipped off that and made the jack land under the floor board itself. The car dropped about, what, 2 inches?
Old Apr 5, 2006 | 05:00 AM
Hotshot940's Avatar
this happened to me too, i let my friend jack my car up and 5 minutes later, BAM, car falls on the jack and it pushed up a section of my rear seat floor. i was SO pissed off.
Old Apr 5, 2006 | 05:03 AM
saw22's Avatar
Have you fixed it yet? I wish mine was in any other floor board but the driver's I know its something I would get used to, but anyone else that drove it would be like "WTF?". Big red flag on trade-in day too, of course.
Old Apr 5, 2006 | 05:27 AM
rcheung's Avatar
I had couple of cars which were jacked in the wrong place and the same thing happened. All you need to do is get a hammer and bang that sucker back down. Dont use a rubber mallet use a regular hammer.
Old Apr 5, 2006 | 05:49 AM
BADEVO's Avatar
Great invention called jack stands. You should invest in them. I dunno but shop rule number 2 we learned was NEVER use a jack to hold a car up. Behind rule number 1 which also applies use the right tool for the job. Glad your not injured.
Old Apr 5, 2006 | 05:51 AM
anjapower's Avatar
I've one upped you. I had just started getting into doing/installing mods on my car (my previous car, not the Evo), and didn't really know how to use a jack. My friend who was also in the same boat, thought the round thing on the floorboard (floor plug) next to the pinch was the spot to jack the car up.
It seemed to make sense since the plug and the cup on the jack were exactly the same size. Well, we started jacking up the car and it went up a couple inches but then it it wouldn't go up too much higher. A couple more pumps on the jack handle and we see the car drop to the ground. We were all like this: ...WTF happened!!!
Well...the jack had pierced clean thru the floor board by popping the plug, and was poking inside my car, lifting the carpet up. I took the car to a bodyshop and the guy who repaired it commented that it was possibly the best place to have pierced the hole as he was able to hammer out the raised area and weld the plug back in.
Since then I've been about 100x more cautious about the way I use the jack, but I've still had two or three incidents.
Old Apr 5, 2006 | 05:52 AM
9g's Avatar
9g
i hope it helps badevo.
Old Apr 5, 2006 | 05:55 AM
stevEVO8's Avatar
Use the jacking points in front and rear and not on the side of the car. I use Rhino ramps for the front most of the time and then jack the rear up and use the stands.
